01-21-2015 07:34 AM - edited 03-17-2019 01:40 AM
Hi everyone.
We have two CM hosts parcitipating of a cluster. We have already created a DCHP option 150 mapping to the IP addressess of the Primay(Publisher) and Secundary(Subscriber) Call managers and the IP phones also get the two TFTP servers IP addresses on the configuration section of the phone. When we disable the primary CM host, the phones cannot register automatically to the secondary CM(also secundary TFTP server).
Is there any configuration on CM publisher where I we redirect the phone registrations to the secundary CM in case of primary publisher failure?
P.S.: on the phone IPv4 configuration, the section: Alternate TFTP is set to NO. I suppose this configuration comes from the Primary CM(publisher).
Thanks in advance.
Rafael.
01-21-2015 07:40 AM
All you've done is provide TFTP redundancy, nothing else, for CUCM redundancy you need to configure the CUCM groups and assign it to phones via device pool.
01-21-2015 09:06 AM
Hi jaime.
CUCM already configured correctly. When we set the TFTP secundary server IP address on DHCP server, the phone start registering correctly (we disable the primary server, the subscriber). The point is: we do this manually. We would like to redirect the phone registrations to the secondary server automatically since the primary server fails.
Thanks.
Rafael.
01-21-2015 07:41 AM
You need to configure both cucm in the cucm group assigned to the device pool of the phones. This is where it knows its primary abd backup cucm server. Have you done this?
01-21-2015 09:02 AM
Hi Ayodeji.
Device Pool is already created.
01-21-2015 09:05 AM
Ok. So do you have a cucm group with two servers in it? Is this cucm group assigned to the device pool? Is this device pool assigned to the phone?
01-21-2015 09:11 AM
Yes Ayodeji. Both call managers primary and secondary are working properly. Only failover is not working. Maybe there is some configuration problem.
Thank you.
01-21-2015 10:02 AM
Can you send us a screen shot o your cucm group and device pool?
How are you simulating fail over? Are you stopping cucm service on subscriber?
01-21-2015 10:28 AM
Failover simulation: we remove the IP address of the primary server TFTP(CM publisher) on the DHCP server and set the TFTP 2 IP adress, so the iphone registration is made automatically on Secondary TFTP 2 (CM subscriber).
I am sorry about the lack of information. I just started my studies with Cisco Voice technologies.
01-21-2015 10:38 AM
First of all that will not simulate fail over. Secondly your cucm group only has one server and you don't even have a secondary server available. Did you observer you only have one server in your cucm group?
The way to test fail over once you have ensured that you have two servers available is to stop the cucm service on the primary cucm (This is the easiest I can suggest to you. Its not the best way to do it though). The best way is to configure access-list to block sccp traffic to the cucm rom the ip phone subnets
01-21-2015 11:02 AM
I know that won't simulate failover, but I just wanted to be sure that, the secondary server would be reached by the phones if the primary (publisher) was unavailable. So, the phones were able to find the secondary server(subscriber).
So, here you find attached another screen shot with the cluster configuration. There are two servers available.
01-21-2015 11:28 AM
Hi Rafael.
Please browse one of your ip phones pointing your browser to its ip address, click on "Network Configuration" on left menu, take a screeshot of the result page and post it here.
Carlo
01-21-2015 11:42 AM
Hi Carlo. Please check the configuration below:
I am sorry but the previous admin here set the language to portuguese.
Servidor DHCP | 10.103.0.236 | |
Endereço MAC | 500604FAFC36 | |
Nome do host | SEP500604fafc36 | |
Nome do domínio | ""internal content" | |
Endereço IP | 10.101.48.94 | |
Máscara de sub-rede | 255.255.252.0 | |
Servidor TFTP 1 | 10.103.8.10 | |
Servidor TFTP 2 | 10.103.8.11 | |
Roteador padrão 1 | 10.101.48.1 | |
Roteador padrão 2 | ||
Roteador padrão 3 | ||
Roteador padrão 4 | ||
Roteador padrão 5 | ||
Servidor DNS 1 | 10.103.0.227 | |
Servidor DNS 2 | 10.103.0.235 | |
Servidor DNS 3 | 8.8.8.8 | |
Servidor DNS 4 | ||
Servidor DNS 5 | ||
ID da VLAN operacional | 4095 | |
ID da VLAN administrativa | 148 | |
Unified CM 1 | 10.103.8.10 Ativo | |
Unified CM 2 | ||
URL de informações | "internal content" | |
URL de diretórios | "internal content" | |
URL de mensagens | "internal content" | |
URL de serviços | ||
DHCP ativado | Sim | |
Endereço DHCP liberado | Não | |
TFTP Alternativo | Sim | |
URL de inatividade | ||
Tempo URL de inatividade | 0 | |
URL do servidor proxy | ||
URL de autenticação | http://10.103.8.10:8080/ccmcip/authenticate.jsp | |
Sincronização automática de porta | Não | |
Configuração remota da porta do switch | Desativado | |
Configuração remota da porta do computador | Desativado | |
Config. porta do switch | Auto negociar | |
Config. porta computador | Auto negociar | |
Localização do usuário | Portuguese_Brazil | |
Localização da rede | Brazil | |
Fone de ouvido ativado | Sim | |
Versão localização usuário | 8.6.2.1000-1 | |
Versão localização rede | ||
Porta PC desativ. | Não | |
Alto-falante ativado | Sim | |
GARP ativado | Não | |
Capacidade de vídeo ativada | Não | |
VLAN de voz ativada | Sim | |
DSCP para controle chamada | CS3 | |
DSCP para configuração | CS3 | |
DSCP para serviços | DEFAULT | |
Modo de segurança | Não seguro | |
Acesso à Web ativado | Sim | |
Span porta do computador | Não | |
VLAN do PC | 148 | |
CDP: Porta do PC | Sim | |
CDP: Porta do switch | Sim | |
LLDP-MED: Porta do switch | Sim | |
LLDP: Porta do PC | Sim | |
Prioridade da potência LLDP | Desconhecido | |
ID do ativo LLDP | ||
Modo de endereçamento IP | IPv4 apenas | |
Controle de modo de preferências IP | V4 | |
Configuração automática de IPv6 | Sim | |
IPv6 Servidor de carregamento | ||
Servidor de registro IPv6 | ||
Servidor CAPF IPv6 | 10.103.8.10 | |
DHCPv6 | Sim | |
Endereço IPv6 | ||
Tamanho do prefixo de IPv6 | 0 | |
Roteador padrão IPv6 1 | ||
Servidor DNS IPv6 1 | ||
Servidor DNS IPv6 2 | ||
TFTP alternativo IPv6 | Não | |
Servidor TFTP 1 de IPv6 | ||
Servidor TFTP 2 de IPv6 | ||
Endereço IPv6 liberado | Não | |
Nível do EnergyWise | ||
Domínio do EnergyWise |
01-21-2015 11:52 AM
Have you enabled CUCM services on the .11 server? That server is not showing in your cucm group, implies it is not available as a call processing server? Please use the CUCM serviceability page to check that the cucm service is enabled on that server
