Call manager fallback srst no ring
When my system is in fallback to the gateway I have the rolling issue:
1. Pick up the phone and hear dial tone.
2. Press 9 for outside line and then hear no dial tone.
3. Dial number and hear no ring.
How do I enable the dial tone after pressing 9 and how to I get it so the users hear the ringing in the handset so they know the call is working?
Here is config of call-manager-fallback
 secondary-dialtone 9
 max-conferences 2 gain -6
 transfer-system full-consult
 limit-dn 7945 2
 limit-dn 7965 2
 limit-dn anl 1
 ip source-address 10.201.106.2 port 2000
 max-ephones 10
 max-dn 200 no-reg
 system message primary Olivia SRST
 transfer-pattern ....
Can you also provide the config an ephone and its ephone-dn to look at?
Since these are sccp phones, issue the following debug command for one of your phones and place a call with it. Post the output here and we can take a look: debug ephone detail mac-address xxxx.xxxx.xxxx
Maren
The phones that I am running are sip. Could this be an issue as to why I do not hear the dial tone and ringing while in fallback mode?
Is there a special config I need to add to get them working?
