Call Manager License Unit
abuahmed.sd
I have Call Manager ( CUCM ) with 4000 License Unit, I need more than 4000 unit
what is the minimum License Unit can I Buy?
and from where can I Buy to extended my License Unit?
HARIS_HUSSAIN
Contact your Cisco Partner to purchase the license.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Also in terms of ordering license units, if you version 9.x and below for CUCM you are out of luck. You have to look to move to a later version preferably 11.X or higher.
ashish
Response Signature
Thanks for your response, but did you mean I do not have the opportunity to increase my number of licenses? I use an older version of 9.x.
Thanks for your response, I would like to know if I can get a license for a number of less than 1000 units.
