Jabber Client - How to make the SIP URI be the default for "green button" click to dial
bvanbenschoten
Level 5
Level 5
IMP 12.0 on-prem with Jabber for Windows 12.0 (But I think this would apply to most all current releases of IMP/Jabber)
Using only UDS directory with LDAP sync on back end.  LDAP directory is mapping telephoneNumber to Phone Number and mail to Directory URI
The client seems to default to using the Phone Number as the default selection for the green click to dial function.  I have a need to make this default to the SIP URI.
I've checked over the parameters available here
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/12_0/cjab_b_parameters-reference-guide-for-cisco_12.html
but not finding anything in the XML parameters that would seem to influence this.
See screen capture attached here for a visual.JabberClientClickToDialOrder.png
Jaime Valencia
Not AFAIK, that's the same behavior if you use LDAP as directory source. As the DN and URI should be associated in CUCM, that should not make a difference.
java
if this helps, please rate
aneesap90
Anyway to remove this SIP URI from jabber client
thanks
