For Authentication issues , refer Troubleshoot section.
Reason for back up -> Although you can use the subscriber DB for the restore, a backup is still required in order to restore the non-DB components.
No it wont pull database after authentication , follow as per the document to do restore.
If you still have issues , contact TAC.
Mohamed
