Call Manager ver 10.5
dukeminus
my users in NewYork office are complaining that they can not receive any external calls. the person on other end just hear busy signal. Internal calls work find
m.batts
Level 4
Level 4
We could really do with a lot more information.
What connectivity have you to the PSTN. Do you use ISDN? if are the circuits up?
Is this a new installation? has it working in the past
m.batts
Level 4
Level 4
Hi m.batts,
What info do you need from PSTN
At the very least, you need to mention what the exact call flow is, if this is CUCM/CME, what version you're using, if this is a SIP trunk, or TDM, if TDM, what you use, etc.
Otherwise, I suggest you reach TAC so someone can log into your system and find that information.
java
if this helps, please rate
Thanks you guys for reaching out. It appears we are having circuit issues
