IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6051 Views
  • 14 replies
When we have a 7800 or 8800 series phone connected over MRA and it is on a call with a user on a jabber client if either end point puts the call on hold the call drops when the call is taken back off hold.  Has anyone seen anything like this before?
Resolved! Restore from DRF
Is it possible to restore CUCM cluster from a working environment to a work environment? The reason why i am asking is because i am stumped doing this. I've been trying to do this via the DRF page but its not finding the TAR files. I backed up the wo...
CISCO IP Phone with SIP 7942 , 7962 , 7975 not showing VPN options under Security  , SCCP is fine We use IP SSL to connect to ASA but we cannot get the SIP phone to show the vpn options Any ideas? Checked SIP profile and templates , Common Phone Pr...
chrherr17 by Level 1
  • 1066 Views
  • 3 replies
Hi, I have been using this setup succesfully for years running on CUCM 6 but since I installed a fresh CUCM 8.0 copy everything works fine accept making outgoing calls. There is nothing changed on my Cube up to now. Setup: CUCM 8.0.3.21900-8 -> SIP t...
Hello, I have one cluster of CUCM 8.6.2 that is showing this message Licensing Warnings: System is operating on insufficient licenses. Please upload additional license files. The Node License Remaining is -1, because the client add a subscribver with...
Hi All, I'm about to integrate our AD into CUCM for it's directory. Ideally I'd like to do a test run, but encountered many problems when trying to login to a vm clone of CM so I sacked it off. So now I just want to go for it, but am concerned how...
action711 by Level 1
  • 288 Views
  • 3 replies
Dears, I am on unity connection 8.6.2ES145.25900-145 Unrestricted i want to move to 11.X restricted,the direct upgrade after installing a COP RSA v3 will be accepted, or there is no way to upgrade from unrestricted to restricted. when i installed fre...
adamgibs7 by Level 6
  • 477 Views
  • 6 replies
