Call manager ver8.62
Kyle Albasha
Hello
I'm running callmanager v 8.6.2 with a hunt pilot configuration utilizing and h list and line group
my q
how do i configure my pilot number to Forward Hunt No Answer & Forward Hunt Busy to internal number .?
tried to set the number directly into section Hunt Forward Settings  with Calling Search Space  internal and didn't work
what is the correct way?
j.huizinga
Level 6
Level 6
It works perfectly, have done it many times.
You have to be carefull with the timers though, try to set the timers on the hunt rather low for testing. Hunt-pilot and the Hunt-list have both timers assosiated with them.
And make sure that partition and CSS are correct.
Jan
