ERROR: cannot initialize phone: Plugin not available (code 1) on HTA
jviladomat1
Dear All,
I've get Jabber working with IE11 without problems.
I'm using, in the client side JabberSDK browser pugin for Windows WebVersion 9.2_MR6
In server side, I've got the sample.HTML and it detects the plugin and Works
When I Access to the same HTML using HTA, I get the following error:
cwic javascript version is 3.0.6.168364
plugin upgrade mandatory
It seems that HTA is not detecting the plugin.
Here you have how I've created the HTA:
<html>
   <head>
      <title></title>
<HTA:APPLICATION
  APPLICATIONNAME="WEBLINE"
  ID="WEBLINE"
  VERSION="1.0"
  BORDER="thin"
  BORDERSTYLE="complex"
  ICON="m_1_normal.ico"
  SINGLEINSTANCE="yes"
  NAVIGABLE="yes"
  CONTEXTMENU="yes"
  SELECTION="yes"
  SYSMENU="yes"
</HEAD>
<style type="text/css">
   body {background-color:lightsteelblue;}
   p {font:bold 18px arial;}
</style>
<BODY >
<script language="JavaScript">
window.resizeTo(1920,1080);
</script>
<form name="entra" action="http://192.8.1.99/webline_iz4/test_josep/cisocbt/samples/sample.html" method=POST></form>
<script language="JavaScript">document.forms("entra").submit ();</script>
</BODY>
</HTML>
Any idea about how to achive the plugin detection from this Kind of application?
Thanks in advance
keglass
Level 7
Level 7
Josep,
This community does not provide technical support and is not staffed with technical support experts. I recommend you post this and future technical support questions to the Cisco Support Community (https://supportforums.cisco.com/index.jspa) where our Cisco technical support experts provide assistance. Another option is to open a ticket with the Cisco Technical Assistance Center (www.cisco.com/go/support) to get expert debugging assistance.
Hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
