call not going out
edwincharles
dears,
need your help, having problem dialing  this number             9 4669400,
attached my config and debug, pls check and help me what is the cause of call disconnect
edwincharles
it worked for me , i added ulaw and alaw in the dialpeers
but another issue i have is , when dialing from exten 555 to outside 4669400 the  call disconnects
from every other extension the call is going out, but only through 555 its not going
any extn dialing outside will use 2837555 as caller id
rule 8 /.../ /2837555/
HI Edwin,
Is this phone a video phone? Is it the only video phone you have in your system ? Does your SIP provider support video attributes over the sip trunk?
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
no ,its 7975
but i tried the same exten on 7911 same problem
hi can anyone help me on this issue
