01-07-2012 01:34 PM - edited 03-16-2019 08:52 AM
Configured Unity Express, created users and created mailboxes. But when I try to test it internally the call is not going. Unkown number is displayed. When 'debug voip ccapi inout command' is executed it is taking the correct dial-peer but showing 'cause value 65' the reason for call not connecting.
How to overcome this?
Fawaz Khan
Solved! Go to Solution.
01-08-2012 03:53 AM
codec g711ulaw
01-08-2012 03:53 AM
codec g711ulaw
01-08-2012 12:09 PM
Thanks a ton..
01-09-2012 02:55 AM
You're welcome, thanks for the nice rating and good luck!
