04-22-2016 08:14 AM - edited 03-17-2019 06:40 AM
Hi Guys,
Need a quick help on call park for analog phones connected on vg224. How to retrieve a parked call from there as I have tried using **6 but that didn't work.
Shyam
04-22-2016 11:14 AM
Any help would be awesome.
04-22-2016 11:21 AM
Hi Shyam,
The default settings for the VG224 feature codes are as follows:
Call Forward All (CFA) **1
Call Forward All Cancel **2
Call Park Directed Call Pickup Directed **6
Call Pickup Group **4>>>>>>>>>>>>>
Call Pickup Local **3
I believe same question has been anwered in another post and you can refer it.
04-22-2016 11:48 AM
Yes I tried **6 and then the pickup extension *0300 but when you start dialing **6 it says call can not be completed.
I have stcapp feature access-code command added too.
04-22-2016 12:08 PM
After researching a bit ,it looks like this feature is not supported with CUCM for analog FXS ports.
Pershaps you can check with Cisco TAC for latest.thank you
04-24-2016 05:45 PM
Hello Shyam
The Call Park feature is not supported on SCCP Ports with Callmanager
server.
Please see
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxssccpsplmft.html
you can Look for "Call Park Directed" and "Call Pickup Directed"
PS: There are some Restriction too while doing that.
Br,
Nadeem
