Call process flow in CUCM
praveen ks
Can any one explain the call flow/process which happen in CUCM when a IP phone try to communicate with local extension and to outside(external) 10 digit number (local/LD). Also how the call process for inbound calls (external). Like phone->CSS->Route partition (my order is wrong).
Jaime Valencia
You need to do some reading on the topic
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/dialplan.html
And all of the chapters under dial plan architecture
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmsys/CUCM_BK_SE5FCFB6_00_cucm-system-guide-100/CUCM_BK_SE5FCFB6_00_cucm-system-guide-100_chapter_01110.html
java
if this helps, please rate
Charles Hill
Here is a diagram that may help with understanding the call flow.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/13920-call-routing.html
Hope this helps
Please rate helpful posts
