Are you sure the config wasn't changed in the time periods to other setting (time or based on originating caller?)
Has the time of the server changed??
I'd suggest you to delete and recreate the config
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
