Call routing via SIP trunks to CMS
jeff.mayers.ctr
Hey guys,
I installed a CUBE in a DMZ that terminates 2 SIP trunks. One from the outside and one that registers to our internal CUCM 10.5. Voice calls from the outside to inside and vice-versa work just fine. From our CUCM cluster there is another SIP trunk that connects to our CMS conferencing box. I can see calls hit the CMS box from the outside customer except the call lasts one sec as they get one ring, then nothing. Our CMS box shows outgoing audio but there is no incoming audio. Call routing here is a mystery as it appears the SIP handshake takes place but then there is no audio. The customer does not hear the outgoing message to enter in a meeting ID or PIN. The subnets are wide open so there should not be an ACL issue. We have set the codecs to match all the way through except still,. no audio.
Any thoughts would be appreciated.
Dennis Mink
can you add a SIP trace of a failing call or add a debug ccsip message output into the post for analysis/
cheers
Please remember to rate useful posts, by clicking on the stars below.
Sorry for the delay. I had to scrub the info.
Here is the "debug ccsip messages" output when the call is made with one ring and then no audio.
Jul 11 16:43:09.544: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:xxxxx@xxx.xxx.xxx.xxx:5060 SIP/2.0
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK-d8754z-305bc80b4b515246-1---d8754z-;rport
Max-Forwards: 70
Contact: <sip:xxx.xxx.xxx.xxx:5060>
To: <sip:xxxxx@xxx.xxx.xxx.xxx:5060>
From: "xxxxxxxxxx"<sip:xxx.xxx.xxx.xxx:5060>;tag=4a18817e
Call-ID: YmI4NzdiZjYxMGM4ODI0ZGNjODU2NzJhNmQ4NWNhYzA.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Content-Type: application/sdp
Supported: replaces
User-Agent: 3CXPhoneSystem 12.5.44288.1005 (40218)
Content-Length: 210
Remote-Party-ID: "xxxxxxxxxx"<sip:xxxxxxxxxx@xxx.xxx.xxx.xxx:5060>;party=calling
v=0
o=3cxPS 352321536000 545695727617 IN IP4 xxx.xxx.xxx.xxx
s=3cxPS Audio call
c=IN IP4 xxx.xxx.xxx.xxx
t=0 0
m=audio 17326 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=sendrecv
Jul 11 16:43:09.547: //179834/53FA4D0D8EF7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 11 Jul 2018 16:43:09 ZULU
CSeq: 1 INVITE
Allow-Events: kpml, telephone-event
Server: Cisco-SIPGateway/IOS-15.5.3.S7b
Content-Length: 0
Jul 11 16:43:09.547: //179835/53FA4D0D8EF7/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:xxxxx@xxx.xxx.xxx.xxx SIP/2.0
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK9B12389
Remote-Party-ID: "xxxxxxxxxx" <sip:xxxxxxxxxx@xxx.xxx.xxx.xxx>;party=calling;screen=no;privacy=off
From: "xxxxxxxxxx" <sip:xxxxxxxxxx@xxx.xxx.xxx.xxx>;tag=D876A7FE-1EA6
To: <sip:xxxxx@xxx.xxx.xxx.xxx>
Call-ID: 53FA9B21-846011E8-8EFDAE67-101A1BFB@xxx.xxx.xxx.xxx
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1408912653-2220888552-2398596711-0270146555
User-Agent: Cisco-SIPGateway/IOS-15.5.3.S7b
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1531327389
Contact: <sip:xxxxxxxxxx@xxx.xxx.xxx.xxx:5060>
Call-Info: <sip:xxx.xxx.xxx.xxx:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 245
v=0
o=CiscoSystemsSIP-GW-UserAgent 8434 65 IN IP4 xxx.xxx.xxx.xxx
s=SIP Call
t=0 0
m=audio 10792 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Jul 11 16:43:09.552: //179835/53FA4D0D8EF7/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Wed, 11 Jul 2018 16:43:09 GMT
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
Jul 11 16:43:09.560: //179835/53FA4D0D8EF7/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:xxxxx@xxx.xxx.xxx.xxx>;tag=13060056~95911e6e-0c62-4a67-ae9d-0a3872f81d61-48764415
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Server: Cisco-CUCM10.5
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Preferred-Identity: <sip:xxxxxx4100@xxx.xxx.xxx.xxx>
Remote-Party-ID: <sip:xxxxxx4100@xxx.xxx.xxx.xxx>;party=called;screen=no;privacy=off
Contact: <sip:xxxxx@xxx.xxx.xxx.xxx:5060>
Content-Length: 0
Jul 11 16:43:09.560: //179834/53FA4D0D8EF7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:xxxxx@xxx.xxx.xxx.xxx:5060>;tag=D876A80C-1DDD
CSeq: 1 INVITE
Content-Length: 0
Jul 11 16:43:09.568: //179835/53FA4D0D8EF7/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Session-Expires: 1800;refresher=uas
Require: timer
Contact: <sip:xxxxx@xxx.xxx.xxx.xxx:5060>;isFocus
Content-Length: 225
v=0
o=CiscoSystemsCCM-SIP 13060056 1 IN IP4 xxx.xxx.xxx.xxx
s=SIP Call
b=TIAS:64000
b=AS:64
t=0 0
m=audio 51808 RTP/AVP 0 101
a=fmtp:101 0-15
Jul 11 16:43:09.569: //179835/53FA4D0D8EF7/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:xxxxx@xxx.xxx.xxx.xxx:5060 SIP/2.0
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK9B21650
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jul 11 16:43:09.570: //179834/53FA4D0D8EF7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 194
v=0
o=CiscoSystemsSIP-GW-UserAgent 8624 8068 IN IP4 xxx.xxx.xxx.xxx
s=SIP Call
t=0 0
m=audio 10790 RTP/AVP 0
a=ptime:20
Jul 11 16:43:09.679: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK-d8754z-231eca71ef5e0b11-1---d8754z-;rport
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
Jul 11 16:43:23.566: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:xxxxxxxxxx@xxx.xxx.xxx.xxx:5060 SIP/2.0
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK70423233d60e8c
From: <sip:xxxxx@xxx.xxx.xxx.xxx>;tag=13060056~95911e6e-0c62-4a67-ae9d-0a3872f81d61-48764415
To: "xxxxxxxxxx" <sip:xxxxxxxxxx@xxx.xxx.xxx.xxx>;tag=D876A7FE-1EA6
User-Agent: Cisco-CUCM10.5
Max-Forwards: 70
CSeq: 101 BYE
Reason: Q.850;cause=16
Content-Length: 0
Jul 11 16:43:23.567: //179834/53FA4D0D8EF7/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:xxx.xxx.xxx.xxx:5060 SIP/2.0
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK9B31CA7
From: <sip:xxxxx@xxx.xxx.xxx.xxx:5060>;tag=D876A80C-1DDD
To: "xxxxxxxxxx"<sip:xxx.xxx.xxx.xxx:5060>;tag=4a18817e
Timestamp: 1531327403
CSeq: 101 BYE
Max-Forwards: 70
Content-Length: 0
Jul 11 16:43:23.567: //179835/53FA4D0D8EF7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 11 Jul 2018 16:43:23 ZULU
CSeq: 101 BYE
Content-Length: 0
Thank you,
Hey guys,
It appears problem solved. During troubleshooting, I witnessed an ACL blocking an IP that did not show up in the past. Once it was accounted for, traffic traversed as expected. The IP address was the CMS box we were trying to call into.
Cheers,
