Call to PSTN busy tone through MGCP gateway
fuhrersk8
Level 3
Level 3
             Hello guys!
     The scenario is the follwong: a 2921 as MGCP gateway and a CUCM8.6. Incoming calls work but outbound calls I get busy tone. Below is the debug ccapi:
025361: Mar  4 15:12:22.583 UTC: //-1/CCAPI/cc_get_call_entry:
   CALL_ERROR_INFORMATIONAL; Call Id Is Invalid=-1
025362: Mar  4 15:12:22.583 UTC: //-1/CCAPI/ccDigitDialStop:
   CALL_ERROR_INFORMATIONAL; Call Entry Is Not Found
025363: Mar  4 15:12:22.583 UTC: //-1/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x30FF6240, Interface Type=6, Destination=7872350808, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7872350808(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=A0000000018e1465000000F5)
025364: Mar  4 15:12:22.587 UTC: //-1/CCAPI/cc_get_feature_vsa:
025365: Mar  4 15:12:22.587 UTC: :cc_get_feature_vsa malloc success
025366: Mar  4 15:12:22.587 UTC: //-1/CCAPI/cc_get_feature_vsa:
025367: Mar  4 15:12:22.587 UTC:  cc_get_feature_vsa count is 1
025368: Mar  4 15:12:22.587 UTC: //-1/CCAPI/cc_get_feature_vsa:
025369: Mar  4 15:12:22.587 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:827239728,feature_id:707
025370: Mar  4 15:12:22.587 UTC: //3968/CCAPI/cc_insert_call_entry:
   Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
025371: Mar  4 15:12:22.587 UTC: //-1/CCAPI/cc_init_call_entry:
025372: Mar  4 15:12:22.587 UTC:  call_init_entry calle is 2BD4D980,callid is 3968
025373: Mar  4 15:12:22.587 UTC: //3968/CCAPI/cc_init_call_entry:
025374: Mar  4 15:12:22.587 UTC: //3968/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=3968
025375: Mar  4 15:12:22.587 UTC: //3968/CCAPI/cc_set_voice_port_value:
   CC_IF_TELEPHONY: Echo=1, Playout=1
025376: Mar  4 15:12:22.587 UTC: //0/CCAPI/cc_get_call_entry:
025377: Mar  4 15:12:22.587 UTC: //3968/CCAPI/ccDirectEventToSPI:exit@9942
025378: Mar  4 15:12:22.587 UTC: //3968/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
025379: Mar  4 15:12:22.587 UTC: //3968/CCAPI/ccCallSetContext:
   Context=0x2ACC4068
025380: Mar  4 15:12:22.587 UTC: //-1/CCAPI/ccCodecPresent:
   codec 17
025381: Mar  4 15:12:22.587 UTC: //-1/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x2B6DC560, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
025382: Mar  4 15:12:22.587 UTC: //-1/CCAPI/cc_get_feature_vsa:
025383: Mar  4 15:12:22.587 UTC: :cc_get_feature_vsa malloc success
025384: Mar  4 15:12:22.587 UTC: //-1/CCAPI/cc_get_feature_vsa:
025385: Mar  4 15:12:22.587 UTC:  cc_get_feature_vsa count is 2
025386: Mar  4 15:12:22.587 UTC: //-1/CCAPI/cc_get_feature_vsa:
025387: Mar  4 15:12:22.587 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:827239056,feature_id:708
025388: Mar  4 15:12:22.587 UTC: //3969/CCAPI/cc_insert_call_entry:
   Total Call Count=0, Call Entry(Call Count On=TRUE, Incoming Call=FALSE)
025389: Mar  4 15:12:22.587 UTC: //3969/CCAPI/cc_insert_call_entry:
   Total Call Count=1
025390: Mar  4 15:12:22.587 UTC: //-1/CCAPI/cc_init_call_entry:
025391: Mar  4 15:12:22.587 UTC:  call_init_entry calle is 2BD4BF70,callid is 3969
025392: Mar  4 15:12:22.587 UTC: //3969/CCAPI/cc_init_call_entry:
025393: Mar  4 15:12:22.587 UTC: //3969/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=3969
025394: Mar  4 15:12:22.587 UTC: //3969/CCAPI/cc_set_voice_port_value:
   CC_IF_RTP: vad=0, modem_pro=2, modem_codec=1
025395: Mar  4 15:12:22.587 UTC: //0/CCAPI/cc_get_call_entry:
025396: Mar  4 15:12:22.587 UTC: //3969/CCAPI/ccDirectEventToSPI:exit@9942
025397: Mar  4 15:12:22.587 UTC: //3969/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
025398: Mar  4 15:12:22.587 UTC: //3969/CCAPI/ccCallSetContext:
   Context=0x2ACC3FB8
025399: Mar  4 15:12:22.587 UTC: //3969/CCAPI/cc_api_call_connected:
   Interface=0x2B6DC560, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
025400: Mar  4 15:12:22.587 UTC: //-1/CCAPI/cc_set_conf_start_tstamp:
025401: Mar  4 15:12:22.587 UTC:  cc_set_conf_start_tstamp: no confID set - confID:0
025402: Mar  4 15:12:22.587 UTC: //3969/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
025403: Mar  4 15:12:22.587 UTC: //3969/CCAPI/cc_api_call_connected:exit@6116
025404: Mar  4 15:12:22.587 UTC: //3969/CCAPI/cc_api_insert_call_active_entry:
025405: Mar  4 15:12:22.587 UTC: //3969/CCAPI/cc_incr_if_call_volume:
025406: Mar  4 15:12:22.587 UTC: //3969/CCAPI/cc_incr_if_call_volume:
   Remote IP Address
025407: Mar  4 15:12:22.587 UTC: //3969/CCAPI/cc_incr_if_call_volume:
   Total Call Count=1, Voip Call Count=1, MMoip Call Count=0
025408: Mar  4 15:12:22.587 UTC: //0/CCAPI/cc_get_call_entry:
025409: Mar  4 15:12:22.587 UTC: //0/CCAPI/cc_get_call_entry:
025410: Mar  4 15:12:22.587 UTC: //0/CCAPI/cc_api_get_ic_leg_obtained_numbers:
025411: Mar  4 15:12:22.587 UTC: //-1/CCAPI/cc_set_outpulsed_digits:
   outpulsed_dialstring=7872350808 set
025412: Mar  4 15:12:22.587 UTC: //3968/CCAPI/cc_api_insert_call_active_entry:
025413: Mar  4 15:12:22.587 UTC: //3968/CCAPI/cc_incr_if_call_volume:
025414: Mar  4 15:12:22.587 UTC: //3968/CCAPI/cc_api_call_disconnected:
   Cause Value=17, Interface=0x30FF6240, Call Id=3968
025415: Mar  4 15:12:22.587 UTC: //3968/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=17, Retry Count=0)
025416: Mar  4 15:12:22.587 UTC: //3969/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
025417: Mar  4 15:12:22.587 UTC: //3969/CCAPI/ccCallDisconnect:
   Start Calling Accounting;
   Call Entry(Incoming=FALSE)
025418: Mar  4 15:12:22.587 UTC: //3969/CCAPI/ccCallDisconnect:
   Cause Value=47, Call Entry(Disconnect Cause=0)
025419: Mar  4 15:12:22.587 UTC: //3969/CCAPI/ccCallDisconnect:
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
025420: Mar  4 15:12:22.587 UTC: //3968/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=17)
025421: Mar  4 15:12:22.591 UTC: //3968/CCAPI/ccCallDisconnect:
025422: Mar  4 15:12:22.591 UTC: //3968/CCAPI/ccCallDisconnect:
   Cause Value=47, Call Entry(Disconnect Cause=17)
025423: Mar  4 15:12:22.591 UTC: //3968/CCAPI/ccCallDisconnect:
025424: Mar  4 15:12:22.591 UTC: //3968/CCAPI/ccCallDisconnect:
   Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
025425: Mar  4 15:12:22.591 UTC: //3968/CCAPI/cc_api_get_transfer_info:
025426: Mar  4 15:12:22.591 UTC: //3968/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
025427: Mar  4 15:12:22.591 UTC: //3968/CCAPI/cc_api_insert_call_history:
025428: Mar  4 15:12:22.591 UTC: //3968/CCAPI/ccGetCallActiveByCallID:
025429: Mar  4 15:12:22.591 UTC: //3968/CCAPI/ccGetCallActiveByCallID:exit@12594
025430: Mar  4 15:12:22.591 UTC: //-1/CCAPI/cc_get_call_entry:
025431: Mar  4 15:12:22.591 UTC: //-1/CCAPI/cc_api_request_rt_packet_stats:
025432: Mar  4 15:12:22.591 UTC: //-1/CCAPI/cc_api_icpif:
   ExpectFactor=0xA
025433: Mar  4 15:12:22.591 UTC: //3969/CCAPI/cc_api_insert_call_history:
025434: Mar  4 15:12:22.591 UTC: //3969/CCAPI/ccGetCallActiveByCallID:
025435: Mar  4 15:12:22.591 UTC: //3969/CCAPI/cc_decr_if_call_volume:
025436: Mar  4 15:12:22.591 UTC: //3969/CCAPI/cc_decr_if_call_volume:
   Remote IP Address
025437: Mar  4 15:12:22.591 UTC: //3969/CCAPI/cc_decr_if_call_volume:
   Total Call Count=0, Voip Call Count=0, MMoip Call Count=0
025438: Mar  4 15:12:22.591 UTC: //3969/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2B6DC560, Tag=0x0, Call Id=3969,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
025439: Mar  4 15:12:22.591 UTC: //3969/CCAPI/cc_disconnect_notify:
025440: Mar  4 15:12:22.591 UTC: //3969/CCAPI/callStackPop:exit@4886
025441: Mar  4 15:12:22.591 UTC: //3969/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
025442: Mar  4 15:12:22.591 UTC: //3969/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
025443: Mar  4 15:12:22.591 UTC: //3969/CCAPI/cc_delete_guid_pod_entry:exit@1165
025444: Mar  4 15:12:22.591 UTC: //-1/CCAPI/cc_free_feature_vsa:
025445: Mar  4 15:12:22.591 UTC: :cc_free_feature_vsa freeing 314EAA88
025446: Mar  4 15:12:22.591 UTC: //-1/CCAPI/cc_free_feature_vsa:
025447: Mar  4 15:12:22.591 UTC:  vsacount in free is 1
025448: Mar  4 15:12:22.591 UTC: //3969/CCAPI/cc_delete_call_entry:
   Total Call Count=1, Call Entry(Call Count On=TRUE, Incoming Call=FALSE)
025449: Mar  4 15:12:22.591 UTC: //3969/CCAPI/cc_delete_call_entry:
   Total Call Count=0
025450: Mar  4 15:12:22.591 UTC: //3968/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30FF6240, Tag=0x0, Call Id=3968,
   Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
025451: Mar  4 15:12:22.591 UTC: //3968/CCAPI/cc_disconnect_notify:
025452: Mar  4 15:12:22.591 UTC: //3968/CCAPI/callStackPop:exit@4886
025453: Mar  4 15:12:22.591 UTC: //3968/CCAPI/cc_api_call_disconnect_done:
025454: Mar  4 15:12:22.591 UTC: //3968/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
025455: Mar  4 15:12:22.591 UTC: //3968/CCAPI/cc_delete_guid_pod_entry:exit@1165
025456: Mar  4 15:12:22.591 UTC: //-1/CCAPI/cc_free_feature_vsa:
025457: Mar  4 15:12:22.591 UTC: :cc_free_feature_vsa freeing 314EAD28
025458: Mar  4 15:12:22.591 UTC: //-1/CCAPI/cc_free_feature_vsa:
025459: Mar  4 15:12:22.591 UTC:  vsacount in free is 0
025460: Mar  4 15:12:22.591 UTC: //3968/CCAPI/cc_delete_call_entry:
025461: Mar  4 15:12:22.591 UTC: //3968/CCAPI/cc_delete_call_entry:
   Deleting profileTable[0x3139E000]
025462: Mar  4 15:12:22.591 UTC: //-1/CCAPI/cc_get_call_entry:
025463: Mar  4 15:12:22.591 UTC: //-1/CCAPI/ccDigitDialStop:
025464: Mar  4 15:12:22.595 UTC: //-1/CCAPI/cc_get_call_entry:
025465: Mar  4 15:12:22.595 UTC: //-1/CCAPI/ccDigitDialStop:
0 Replies 0
