04-19-2017 03:20 AM - edited 03-17-2019 10:06 AM
I have configured CME version 11.5 on Cisco 4400 series ISR. i have configure 7821 , 8831, 8865 and 8945 as SIP phones. But aren't able to have the following features.
Kindly suggest me solution over it.
Thanks in advance.
04-19-2017 06:15 AM
Hi Muneeb,
Please verify the config as per the CME admin guide
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmetrans.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmedirs.html
Manish
04-19-2017 08:06 AM
hi Muneeb
for sip phones, you need to create a template for softkeys and then assign it to the particular device
eg..under voice register template <no>, enable the type of transfer and then under voice register pool, assign that template using
"template <no>" and then create a profile and restart
Call history works by default .if not working, let me know the firmware of phone you are using.
04-20-2017 12:30 AM
Hi Saurabh Khaneja,
Hope you are doing fine. Thanks for the replay.
Let me give you the brief overview of the problem, for call transfer.
Scenario:
Step 1: Caller 1 Calls to Caller 2, and calls connected.
Step 2: Caller 1 press the transfer button and transfer the call to Caller 3.
Step 3: Caller 3 receive's the call and sooner Caller 1 release the call. Caller 2 gets the busy tone whereas Caller 3 didn't heard anything.
Step 4: When Caller 2 hang-up the phone, calls ended with as Caller 1 ended the call.
If still you think i should go for template and it will resolve this issue, then i will made the changes.
Secondly, if you required the running config of the system, i will post it as well for you.
04-21-2017 12:02 AM
Hi Saurabh Khaneja,
Firmware running on CME are as follow.
load 7821 sip78xx.10-4-1SR1-3-3
load 8831 sip8831.10-3-1SR3-5.loads
