10-02-2013 01:45 AM - edited 03-16-2019 07:39 PM
Hiii,
I have a SIP with Avaya and I want CallManger to receive the the last 4 digits from Avaya, from where I have to do the change?
SIP/Trunk Profile?
Th!
10-02-2013 01:50 AM
Hi Gabriel,
On the SIP Trunk, Under "Inbound Calls" > "Significant Digits" , set this value to 4 and reset the SIP trunk.
Manish
10-02-2013 02:08 AM
And if the Avaya sent 7 digits and I want to receive only the last 4 is the same settings?
10-02-2013 02:18 AM
Yes.
Manish
03-20-2014 01:42 AM
Still not working, i made the config from this documentation:
http://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise/interoperability-portal/966105.pdf
The config end at page 29-30 because the providers he said is not necessary to add on Call Manager, what do you think about this?
03-20-2014 02:08 AM
have you set up the SIP trunk following the above guide (p-20 to 25)?
please crosscheck whether you have set the significant digits to 4 under Inbound Call settings (p-24)
Through RTMT session trace, you can check these SIP Trunk calls and its flow.
Please collect the CCM traces for a nonworking call and provide the calling, called party numbers.
03-20-2014 07:09 AM
Yes from 20/25.
03-20-2014 07:09 AM
Could you please collect the traces from CUCM using RTMT?
Here is the guide: https://supportforums.cisco.com/document/126666/collecting-cucm-traces-cucm-862-tac-sr
03-21-2014 01:39 AM
This colect from RTMT and open with CUC Tracer Translator.
03/21/2014 07:54:58.136 |//SIP/SIPTcp/wait_SdlSPISignal: Outgoing SIP TCP message to 10.200.160.1 on port 5060 index 105222
[6799248,NET]
OPTIONS sip:10.200.160.1:5060 SIP/2.0
Via: SIP/2.0/TCP 10.156.100.1:5060;branch=z9hG4bK1afb027e54e6
To: <sip:10.200.160.1>
Date: Fri, 21 Mar 2014 05:54:58 GMT
Call-ID: 5438aa80-32b1d432-1a559-5c4d90a@0.156.100.1
User-Agent: Cisco-CUCM8.6
CSeq: 101 OPTIONS
Contact: <sip:0.156.100.1:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
Source Filename: ccm00000191.txt.gz
