09-08-2012 06:58 AM - edited 03-16-2019 01:06 PM
I am facing issues with caller display. When any user calls in from one cluster to an user who is setup on another cluster, it doesn't display the caller name on phone screen. Can anyone please let me know what might be the issue.
Thank you
09-08-2012 08:32 AM
What CUCM version are you running on both clusters? How have you integrated both clusters?
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
09-08-2012 09:16 AM
Both the clusters are running with CUCM 7.1.5.
These clusters are not integrated as one is deployed in Asia and another in US.
Are there any configs which needs to put in on Gatekeepers/Gateways ?
09-08-2012 09:33 AM
So how are calls routed between the clusters? Intercluster trunk? Gatekeepers?
09-08-2012 10:41 AM
Its through Gatekeepers...
09-09-2012 12:17 AM
- Confirm that "Display IE Delivery" option in your ICT-Gatekeeper Controlled trunk is checked.
- Are there any caller ID display restrictions in the RP/RL/RG matched for the called number?
- Cross check whether calling names are configured under your DNs.
Also, share your CUCM traces when the call is initiated to see whether Display IE is sent with call setup or not.
"Please rate useful posts"
09-09-2012 12:45 AM
Thank you for your reply. I will check on this.
