hi
2851 ccme router and pri line.
when i call outside my extension numbers are missing and pri main number is seen as callerID
debug isdn q931 oputput show correct numbers.
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98383
Exclusive, Channel 3
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '3335722'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '05332176396'
i mean pri number is 3335700 and did numbers are 57xx. But when i check my cell phone it look 3335700 instead of 3335722
the only thing that i did is to add prefix '5' for incoming calls by using
voice translation-rule 1
rule 1 // /5/
because the customer wanted to use 57xx extensions. and DID calls working without problem
debug isdnb q931 for incoming calls
tr#
Mar 20 12:05:11.675: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0DE5
Standard = CCITT
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x0183, '05325414916'
Called Party Number i = 0xC1, '722'
Plan:ISDN, Type:Subscriber(local)
Sending Complete
i added prefix 5 for match extensions 57xx
note
dial-peer voice 1 pots
corlist outgoing external
description calls over pri
translation-profile incoming prefix
destination-pattern 9T
direct-inward-dial
port 0/0/0:15
