Caller ID for Fax on H323 Wrong Info
atallah24
I am having a problem with the caller ID for a Fax machine that is on an h323.
The faxmachines are developed only on the router themselves no CUCM or other system.
I have tried enabling the caller id and the station-id with no luck.
Does someone know the commands to update the caller id or so information that could help configure it correctly.
yuanwu
Hi, Manuel
please provide the detail call flow with all the components involved, such as router model, what kind of VIC card, show version and show run of the router,
what is the exact issue you have for the caller id for FAX m/c, no caller id, or wrong caller id....
Rgds/Randy
