IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5538 Views
  • 14 replies
Hello All,I did an upgrade on the CUCM from version 7.1.3 to 7.1.5 but discovered that Corporate Directory provision on one of the Phone button is no longer working. Because we use extension mobility the Corporate Directory was subcribed to User Prof...
justserve by Level 1
  • 642 Views
  • 5 replies
Hello all,I am doing and install of Unified Business Attendant Console and am running into and error during the install.During the install on the page where you fill out the call manager ip address, the application user you create and its password.I ...
Hi,I did a remote site implementation a few months ago. My superior had purchased a Cisco ESW 540 8-Port POE switch to use with the 2811 router there. The 2811 is setup as an H.323 gw.  I did not have time to figure out how to configure the switch, a...
I saw a couple similar posts, but no resolution...I have a simple Sub/Pub cluster running 7.1(5).  7945's and 7965's with SCCP45.9-0-2SR1S register fine with Pub, but I get "Registration Rejected: Security Error" trying to register to Sub.Thoughts?Th...
So I am configuring a Hunt Pilot in which it hunts through certain numbers first then I have a "Forward Hunt no answer" to the destination of *HuntPilotNO".The star in front of it will take it to voicemail.  Is there anyway to make it ring more than ...
latintrpt by Level 1
  • 913 Views
  • 4 replies
Hello EverybodyI need a help with regard to the following:I have one EM-HDA-6FXO module installed on router Cisco 2951, and i need to establish power-fail connections in an emergency. The question is, how many analog phones can i connect on this modu...
