02-21-2018 04:39 PM - edited 03-17-2019 12:15 PM
Dear All,
My IS4K has running AA sevice.When I press '0' It go to operator and when I press '1' go to option menu to dial the know extension number.It is fine.But the problem is unable to see the Caller-ID of incoming phone number.If i enable call ID service, call unable to reach AA.
On another FXO port that do not run AA-service,but Caller-ID enable.The call come from that port go to fall into AA service.When i disable the caller-ID .It directly go to associate extension.For that FXO port I set the connection plar opx to local extension.
Can anyone help to fix this issue.
voice-port 0/1/0
trunk-group PSTN
connection plar opx 2000
description 3592390
caller-id enable
voice-port 0/1/1
trunk-group PSTN
description 3592395
caller-id enable
voice-port 0/1/2
trunk-group PSTN
description 3592392
caller-id enable
voice-port 0/1/3
trunk-group PSTN
description 3592393
caller-id enable
voice-port 0/2/0
trunk-group PSTN
description 3592394
caller-id enable
voice-port 0/2/1
connection plar opx 2012
description 3592395_for_FactoryManager
caller-id enable
voice-port 0/2/2
description 3592396-FAX
voice-port 0/2/3
description null
dial-peer voice 100 pots
answer-address .
port 0/1/0
dial-peer voice 101 pots
answer-address .
port 0/1/1
dial-peer voice 102 pots
answer-address .
port 0/1/2
dial-peer voice 103 pots
answer-address .
port 0/1/3
dial-peer voice 104 pots
answer-address .
port 0/2/0
dial-peer voice 105 pots
service aa-test
answer-address .
port 0/2/3
Solved! Go to Solution.
02-22-2018 07:33 AM
02-21-2018 05:07 PM
You don't see the caller-id at all or do you see the caller id as the B-ACD pilot ?
02-21-2018 05:09 PM
I see nothing for the incoming call number.
02-21-2018 09:04 PM
When you enable callerid feature it would probably match the dialpeer 105 because of the answer-address .
Please try to remove the answer address command on all Dialpeers and activate a debug voip dialpeer inout.
Please also attach the output here.
Carlo
02-21-2018 10:18 PM - edited 02-21-2018 11:43 PM
Dear Carlo Poggiarelli
I am send wrong script but it is the same issue.Please check the script below.As you say I remove "answer address ." from dial-peer ports.I call the PSTN number on port0/1/0 while debugging on.Please check the attached file.
service aa-test
port 0/1/0
service aa-test
port 0/1/1
service aa-test
port 0/1/2
service aa-test
port 0/1/3
service aa-test
port 0/2/0
02-21-2018 11:46 PM
Can you please post your actual configuration?
Carlo
02-21-2018 11:53 PM
Dear Carlo Poggiarelli,
Please kindly check the attached file.Previsou debugging is running on that config.
02-22-2018 07:33 AM
02-23-2018 07:28 AM
Dear Nipun Singh Raghav ,
I change the another script and all are working fine.Thanks for helping me.I used its-cisco.2.0.3.0.tcl script.
