02-16-2018 02:22 AM - edited 03-17-2019 12:13 PM
Dear all,
I am using Cisco IP phone 3905 with CME 10.5.Unable to dial the 3905 phone in microphone pickup condition.After pressing 5 digit it stop and stick.But in hand-free condition it is ok.How to solve that issue.
I can able to make call with thirdparty phone normally.
Solved! Go to Solution.
02-20-2018 09:05 AM
02-23-2018 07:24 AM
Yes please. I see this marked as solution. Is the issue resolved or are we still pending testing ?
02-16-2018 04:37 AM
02-16-2018 06:31 PM
Dear Nipun Singh Raghav,
Yes your right!
Pickup condition mean call with phone handset and Hand free mean speaker phone mode.
02-20-2018 07:00 AM
02-20-2018 07:24 AM
Dear Nipun Singh Raghav ,
Actually when I make call with 3905 IP phone,I pickup the phone-handset and press the number key.After I press about five keys before all phone number finish,the phone automatically sticky
For example: When I press 09912345678,the phone is stick at 9909 and unable to make call in handset mode and speaker phone mode.But It is enable to dial when I press all number key and open the speaker phone mode or pick the handset.For that number is matching with the following dial-peer voice 2 pots.
trunkgroup PSTN
corlist outgoing callMOBILE
description 09_Mobile
destination-pattern 909T
prefix 09
02-20-2018 07:58 AM
02-20-2018 08:05 AM
Yes sure,please kindly check!
voice service voip
allow-connections sip to sip
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0/0
registrar server expires max 600 min 300
voice register global
mode cme
source-address 10.113.16.226 port 5060
max-dn 30
max-pool 30
load 7960-7940 P0S3-08-6-00.loads
load 3905 CP3905.9-4-1SR2-2.loads
authenticate register
timezone 41
tftp-path flash:
create profile sync 0001625466713364
auto-register
voice register dn 1
number 2000
name Reception
label Reception
voice register pool 1
id mac 247E.12BE.D61F
type 3905
number 1 dn 1
dtmf-relay sip-notify
username 2000 password cisco
description LEVEL-1
codec g711ulaw
!## for international call##International call start with 00##
dial-peer voice 10 pots
trunkgroup PSTN
corlist outgoing callINTERNATIONAL
description 00_International
destination-pattern 900T
forward-digits 0
prefix 00
!## for mobile call##All mobile start with 09##
trunkgroup PSTN
prefix 09
02-20-2018 08:00 AM
02-20-2018 08:08 AM
Plaese kindly check the complete script as attached file.
02-20-2018 09:05 AM
02-20-2018 09:13 AM
Do I need to add this script to my config. and testing again ?You mean like that?
voice register pool X(dn 1-28)#Do you mean that#
no digit collect kpml
dtmf-relay rtp-nte
no create profile
create profile
02-23-2018 07:24 AM
