ā09-08-2010 11:46 PM - edited ā03-16-2019 12:41 AM
Hi, I am having a problem with caller id. I am receiving something like 55E6E6D in the caller id. Is there any translation rule I can use to strip all the letters or replace them with digits? I am using Cisco AS5400. Thanks.
Solved! Go to Solution.
ā09-10-2010 06:55 AM
Oh it is coming in SIP with that. Okay, well technically that should be valid since the from field can be a username instead of an e164 number.
I haven't tried applying this to see how it works, but it at least lets me create a voice translation rule with E's.
2821-Pod3(config)#voice translation-rule 1
2821-Pod3(cfg-translation-rule)#rule 1 /^55E6B6E$/ /5551234567/
I was hoping you would collect the CCAPI output so that I could see what the ani in the call control stack is populated with. Try applying that rule to a profile on the calling number on your inbound peer match. If it doesn't work, get:
debug voip ccapi inout
debug ccsip all
debug voice translation
ā09-09-2010 10:47 AM
You are talking about the calling party number, and not the ISDN call ID (or call reference), right? Are you sure that 'debug voip ccapi inout' shows the cisco-ani field as '55E6E6D?' Can you paste the q931 and CCAPI debug output for a call? The calling party number can be represented in hex, but I'd expect it to show as 0x55E6E6D instead of just 55E6E6D.
E is not a valid DTMF digit for a calling party number. Hence, a translation isn't going to work.
Also, verify that your switch type confiugration matches the ISDN protocol which the provider has your cirucit provisioned for.
ā09-09-2010 09:04 PM
Thank you so much for helping me. Yes, it is calling party number. The call comes in from the voip leg. Here is the output from the ccsip debug output. I only removed the IP address information. The calling number is 55E6B6E.
Sep 8 11:55:35 x.x.x.x 310976: Sep 8 11:55:35.393 PST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sep 8 11:55:35 x.x.x.x 310977: Received:
Sep 8 11:55:35 x.x.x.x 310978: INVITE sip:1051512142330030@x.x.x.x:5060;user=phone;transport=udp SIP/2.0^M
Sep 8 11:55:35 x.x.x.x 310979: Via: SIP/2.0/UDP x.x.x.x:5060;branch=z9hG4bK+446def525b6404ca5149421b8b7d74361+x.x.x.x5060+1^M
Sep 8 11:55:35 x.x.x.x 310980: From: <55E6B6E>;tag=x.x.x.x5060+1+350f0002+159091b4^M
Sep 8 11:55:35 x.x.x.x 310981: To: <1051512142330030>^M
Sep 8 11:55:35 x.x.x.x 310982: CSeq: 539693533 INVITE^M
Sep 8 11:55:35 x.x.x.x 310983: Expires: 180^M
Sep 8 11:55:35 x.x.x.x 310984: Supported: replaces^M
Sep 8 11:55:35 x.x.x.x 310985: Request-Disposition: fork, sequential^M
Sep 8 11:55:35 x.x.x.x 310986: Allow: INVITE, BYE, REGISTER, ACK, OPTIONS, CANCEL, SUBSCRIBE, NOTIFY, P
Sep 8 11:55:35 x.x.x.x 310987: RACK, INFO, REFER, UPDATE^M
Sep 8 11:55:35 x.x.x.x 310988: Call-ID: 7B11890-325AA7@x.x.x.x^M
Sep 8 11:55:35 x.x.x.x 310989: Max-Forwards: 67^M
Sep 8 11:55:35 x.x.x.x 310990: Contact: <55E6B6E>^M
Sep 8 11:55:35 x.x.x.x 310991: Content-Type: application/sdp^M
Sep 8 11:55:35 x.x.x.x 310992: Content-Length: 267^M
Sep 8 11:55:35 x.x.x.x 310993: ^M
Sep 8 11:55:35 x.x.x.x 310994: v=0^M
Sep 8 11:55:35 x.x.x.x 310995: o=nt02-1w-lax 284636161 1283970704 IN IP4 x.x.x.x^M
Sep 8 11:55:35 x.x.x.x 310996: s=sip call^M
Sep 8 11:55:35 x.x.x.x 310997: c=IN IP4 x.x.x.x^M
Sep 8 11:55:35 x.x.x.x 310998: t=0 0^M
Sep 8 11:55:35 x.x.x.x 310999: m=audio 37516 RTP/AVP 18 0 101^M
Sep 8 11:55:35 x.x.x.x 311000: a=ptime:20^M
Sep 8 11:55:35 x.x.x.x 311001: a=fmtp:101 0-15^M
Sep 8 11:55:35 x.x.x.x 311002: a=rtpmap:101 telephone-event/8000^M
Sep 8 11:55:35 x.x.x.x 311003: a=rtpmap:0 PCMU/8000^M
Sep 8 11:55:35 x.x.x.x 311004: a=fmtp:18 annexb=no^M
Sep 8 11:55:35 x.x.x.x 311005: a=rtpmap:18 G729/8000^M
Sep 8 11:55:35 x.x.x.x 311006:
Sep 8 11:55:35 x.x.x.x 311007: Sep 8 11:55:35.39355E6B6E>1051512142330030>55E6B6E>
Sep 8 11:55:49 x.x.x.x 311218: Sep 8 11:55:48.601 PST: //362422/7F68722F8879/SIP/Call/sipSPICallInfo:
Sep 8 11:55:49 x.x.x.x 311219: The Call Setup Information is:
Sep 8 11:55:49 x.x.x.x 311220: Call Control Block (CCB) : 0x69BAEA34
Sep 8 11:55:49 x.x.x.x 311221: State of The Call : STATE_DEAD
Sep 8 11:55:49 x.x.x.x 311222: TCP Sockets Used : NO
Sep 8 11:55:49 x.x.x.x 311223: Calling Number : 55E6B6E
Sep 8 11:55:49 x.x.x.x 311224: Called Number : 1051512142330030
Sep 8 11:55:49 x.x.x.x 311225: Source IP Address (Sig ): x.x.x.x
debug ccsip all
ā09-10-2010 08:45 PM
The translation rule worked. Thank you very much your help. I am wondering if it is possible to get a more general rule to get rid of the letters in the calling number in case something similar comes in.
ā09-11-2010 05:12 AM
It's just a regular expression, so you can be more generic with the match, sure.
Look at the following document for specific examples. If you want to overwrite everything, just use /^.*/ as the mach string.
