12-20-2011 01:45 PM - edited 03-16-2019 08:38 AM
Can one manipulate the Caller ID for ingress calls from PSTN, either on the GW or Callmanager? I think you can't but wanted to confirm with the gurus!
Solved! Go to Solution.
12-20-2011 03:06 PM
You can manipulate the caller id ingress with translation rule.
12-20-2011 10:24 PM
You can change it on the gateway if it's h323
Or on cucm either
In the gateway setting using transformation mask
Or
Using a translation pattern as well
Hope this help
If helpful rate
12-20-2011 03:06 PM
12-20-2011 10:24 PM
Or on cucm either
Or
Hope this help
If helpful rate
