Caller id
nicqures
Can one manipulate the Caller ID for ingress calls from PSTN, either on the GW or Callmanager? I think you can't but wanted to confirm with the gurus!
2 Accepted Solutions
jcinco_555
You can manipulate the caller id ingress with translation rule.
Marwan ALshawi
You can change it on the gateway if it's h323
Or on cucm either
In the gateway setting using transformation mask
Or
Using a translation pattern as well
Hope this help
If helpful rate
jcinco_555
Marwan ALshawi
Or on cucm either
Or
Hope this help
If helpful rate
