07-28-2009 06:09 AM - edited 03-18-2019 10:29 AM
Is it possible in CCM 4.1 and Unity 4.2 to use a caller input like "press 1 now" to go to a users cell phone? I tried alternate contact number and subscriber. Niether one seems to route outside it alwasy just rolls back to vmail for the oringinating extension.
07-28-2009 06:53 AM
If you want a CFNA (Call forward No Answer) or CNB you have to configure these field and assign a Mobile Phone capabil Calling Search Space to these options in the Line/Ext configuration Page in CallManager.
The Unity CTI ports(Voice Mail Call Handlers) should not be used to router calls to mobile phones.
Any more information please let me know.
Many Thanks,
Nico
07-28-2009 07:28 AM
If I do a CFNA will that allow it to go tvoicemail or won't that just go straight to the forwarded number?
I am trying to allow a caller to have the option to (1) xfer to secretary, (2) try user on cell phone, or (3)leave a message.
07-28-2009 07:40 AM
Create a dummy call handler, under transfer configure "Yes, ring subscriber at this number: XXXX". that's all you need.
On the one that will have press 2 for mobile, configure attempt transfer to: above call handler
java
if this helps, please rate
08-05-2009 08:25 AM
I am having problems creating the Call Handler. Each time I have done so it sneds the caller straight to our vmail pilot number.
I created a new extension on a 7940 and set that line to CFA to his cell phone. I then set the Attempt Xfer in Unity under Caller Input. It transfers the call succesfully.
Two questions:
1. Is this acceptable or can I use something instead of a configured extension that is set to forward. Seems a bit kooky.
2. When it transfers to cell is it possible to pass through originating callers CLID? Currently is shows our number depending on how I set the mask up in CCM for that line.
08-05-2009 09:21 AM
The issue is config, if you do as i instructed it will work without a phone with CFA.
You can use the CFA phone if you don't mind wasting a device for that.
java
08-07-2009 01:19 PM
Sorry for the delayed response. I have it working with the Call Handler.
Last piece, can I get the CLID to pass through so he can see the originating caller?
