calling CUE voicemail
davieshuw
I've got a UC520 running CME and CUE. CME is running great, so im now configuring CUE. I've installed CUE and thats running.
Ive configured a voicemail number of 200 under VOICEMAIL > CALL HANDLING (on CUE html page)
There's a dial-peer as follows:
dial-peer voice 2000 voip
description ** cue voicemail pilot no **
destination-pattern 200
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711alaw
no vad
and an ephone-dn:
ephone-dn 27 dual-line
mailbox-selection last-redirect-num
number 200
label 200
description 200
name voicemail
When I dial 200, or set a call-forward on no-an to the number 200, I get the unrecognised number beeps instead of voicemail answering the call.
Help please!
pacameron
Level 4
Level 4
Change the codec on the SIP dial peer from G711alaw to G711ulaw.
This should make the calls work
anderson-david
Level 3
Level 3
you don't need the ephone-dn, what is happening is that the system doesn't know where to send the call as you have two different destinations. remove the ephone-dn and all should work
Dave
Right ive removed the ephone dn. When I call 200 it rings once, then I get the unrecognised number beeps.. odd..
pacameron
Level 4
Level 4
It seems g711ulaw and g711alaw are the bane of my life at the moment!!
cheers, works perfectly!
