04-11-2017 05:15 AM - edited 03-17-2019 10:03 AM
Hi All,
I installed CUCM 11.5, and Gateway Cisco Router 2901
i created a TP for the calling number on CUCM from (1103 directory number) to 0537000010 (ten digits), but that doesn't work, when I make a call I hear just tone.
when i make a debug i found that :
GATEWAY-VOIP#term mon
GATEWAY-VOIP#debug
Mar 31 12:56:26.995: ISDN Se0/0/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=48
Mar 31 12:56:27.007: ISDN Se0/0/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=72 isdn
% Incomplete command.
GATEWAY-VOIP#debug isdn
Mar 31 12:56:36.995: ISDN Se0/0/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=72
Mar 31 12:56:36.995: ISDN Se0/0/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=48
Mar 31 12:56:46.995: ISDN Se0/0/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=48
Mar 31 12:56:47.007: ISDN Se0/0/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=72
Mar 31 12:56:49.955: //-1/0044A07F0600/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=Bureau 1
----- ccCallInfo IE subfields -----
cisco-ani=1103
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0648956135
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Mar 31 12:56:49.955: //-1/0044A07F0600/CCAPI/cc_api_call_setup_ind_common:
Interface=0x226FA928, Call Info(
Calling Number=1103,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0648956135(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=79
Mar 31 12:56:49.955: //-1/0044A07F0600/CCAPI/ccCheckClipClir:
In: Calling Number=1103(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=1103(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Mar 31 12:56:49.955: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 31 12:56:49.955: :cc_get_feature_vsa malloc success
Mar 31 12:56:49.955: cc_get_feature_vsa count is 1
Mar 31 12:56:49.955: :FEATURE_VSA attributes are: feature_name:0,feature_time:975739920,feature_id:79
Mar 31 12:56:49.955: //79/0044A07F0600/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=1103(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0648956135(TON=Unknown, NPI=Unknown))
Mar 31 12:56:49.955: //79/0044A07F0600/CCAPI/cc_process_call_setup_ind:
Event=0x229B29B8
Mar 31 12:56:49.955: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 0648956135
Mar 31 12:56:49.955: //79/0044A07F0600/CCAPI/ccCallSetContext:
Context=0x2107B020
>>>>CCAPI handed cid 79 with tag 1 to app "_ManagedAppProcess_Default"
Mar 31 12:56:49.955: //79/0044A07F0600/CCAPI/ccCallProceeding:
Mar 31 12:56:49.955: //79/0044A07F0600/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=3, Params=0x2107DBC0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar 31 12:56:49.955: //79/0044A07F0600/CCAPI/ccCheckClipClir:
Destination Pattern=0[56]........, Called Number=0648956135, Digit Strip=FALSE
Redirect Number=, Display Info=
Account Number=Bureau 1, Final Destination Flag=TRUE,
Guid=0044A07F-1152-E18D-0600-0A010A020707, Outgoing Dial-peer=3
Mar 31 12:56:49.955: //79/0044A07F0600/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=1103
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0648956135
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
Mar 31 12:56:49.955: //79/0044A07F0600/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x3F1CF30C, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=1103,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0648956135(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar 31 12:56:49.959: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 31 12:56:49.959: :cc_get_feature_vsa malloc success
Mar 31 12:56:49.959: cc_get_feature_vsa count is 2
Mar 31 12:56:49.959: :FEATURE_VSA attributes are: feature_name:0,feature_time:975739696,feature_id:80
Mar 31 12:56:49.959: //80/0044A07F0600/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Mar 31 12:56:49.959: //80/0044A07F0600/CCAPI/ccCallSetContext:
Context=0x2107DB70
Mar 31 12:56:49.959: //79/0044A07F0600/CCAPI/ccSaveDialpeerTag:
Mar 31 12:56:49.963: //80/0044A07F0600/CCAPI/cc_api_call_proceeding:
Interface=0x3F1CF30C, Progress Indication=NULL(0)
Mar 31 12:56:51.219: //80/0044A07F0600/CCAPI/cc_api_call_disconnected:
Cause Value=34, Interface=0x3F1CF30C, Call Id=80
Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
Mar 31 12:56:51.219: //79/0044A07F0600/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
Mar 31 12:56:51.219: //80/0044A07F0600/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=80
Mar 31 12:56:51.219: //80/0044A07F0600/CCAPI/ccCallDisconnect:
Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
Mar 31 12:56:51.219: //80/0044A07F0600/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3F1CF30C, Tag=0x0, Call Id=80,
Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Mar 31 12:56:51.219: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
thank you.
Youssef
04-11-2017 06:14 AM
a translation pattern will translate your called number
You need to use calling party transformation pattern
this thread might be of help to you https://supportforums.cisco.com/discussion/12368631/help-calling-party-transformation-patterns
04-17-2017 08:28 PM
Hi Youssef,
It looks like you are using a PRI citcuit with the proivder:
I see that we are having two problem here:
1) Your calling number is going out as 4 digit extension. The provider may not like the a 4 digit extension in the calling number and it why they might be rejecting the call.
- If that is the case, then you would have to check your translation rule and make sure it translate the calling number.
2) The leg facing the provider is getting disconnected with CV=34. This means no circuit/available. Do you have your PRI configured correct?
- You can quickly check this with "show isdn status" to see if the circuit has " multiple frame established"
In addition to the above:
Please share your show run, along with output of the following debugs:
debug voice ccapi inout
debug isdn q931
- Make sure the you take the debugs in the buffer:
conf t
logg buff 999999
exit
clear log.
- Make the test call:
- Do share the calling and called party number as well.
Pulkit
04-18-2017 07:50 AM
Hi Pulsharm, thank you for answer.
Before discussing about the PRI status, I want to know why the number was not translated, in CUCM: Calling Number is 0537000000, with DN: 1103.
In our installation the PRI has about 100 numbers for external calls,
I want to translate all DNs to DID numbers:
DN DID
1103 => 0537810000
1250 => 0537810001
1166 => 0537810002
1230 => 0537810100
In our installation we have to create for each translation a translation role in CUCM, how can we do that? Thank YOU
Youssef
04-18-2017 07:56 AM
There's no way to tell you why it's not working without seeing the configuration on the TP.
If your dial plan does not use DIDs, and your numbering plan is all over the place as the example you provided, yes, most likely you'll need to create a specific configuration for each number.
04-20-2017 08:58 AM
Hi Jaime, thank you.
here is the configuration and Call Log :
Router Configuration :
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
session transport udp
voice class codec 100
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 clear-channel
voice class h323 1
call start fast
voice class dualtone-detect-params 77
freq-max-deviation 30
voice class custom-cptone leave
dualtone conference
frequency 400 800
cadence 400 50 200 50 200 50
voice class custom-cptone joindre
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice class custom-cptone morocco
dualtone disconnect
frequency 435
cadence 500 500
license udi pid CISCO2901/K9 sn FGL204610JC
hw-module pvdm 0/0
username admin privilege 15 password 7 06350E2D491C594852
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
interface Loopback0
no ip address
shutdown
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.2.7.12 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
ip forward-protocol nd
voice-port 0/0/0:15
cptone FR
bearer-cap Speech
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 1
conference-join custom-cptone joindre
conference-leave custom-cptone leave
associate application SCCP
shutdown
dial-peer voice 1 voip
destination-pattern 1...
progress_ind setup enable 3
session target ipv4:10.2.7.13
incoming called-number 0T
codec g711ulaw
no vad
dial-peer voice 2 pots
preference 1
destination-pattern 0T
port 0/1/0
forward-digits all
dial-peer voice 3 pots
description ####les appels Vers GSM et FIXE NATIONAL###
preference 2
destination-pattern 0[56]........
progress_ind alert enable 8
translate-outgoing calling 1
no digit-strip
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 4 pots
description ####les appels Vers FIXE URBAIN###
preference 3
destination-pattern 0537......
no digit-strip
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 5 pots
description ####les appels Vers FIXE NATIONAL###
preference 4
destination-pattern 0[5]........
no digit-strip
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 6 pots
description ####les appels vers les numeros de service###
destination-pattern #...
no digit-strip
direct-inward-dial
port 0/0/0:15
forward-digits all
Call Log :
Apr 20 13:53:39.879: //-1/00F967C00C00/CCAPI/cc_api_display_ie_subfields:
cisco-username=Salon Marocain
cisco-ani=1104
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0648956135
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
Apr 20 13:53:39.879: //-1/00F967C00C00/CCAPI/cc_api_call_setup_ind_common:
Calling Number=1104,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=94
Apr 20 13:53:39.879: //-1/00F967C00C00/CCAPI/ccCheckClipClir:
In: Calling Number=1104(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=1104(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Apr 20 13:53:39.879: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 20 13:53:39.879: :cc_get_feature_vsa malloc success
Apr 20 13:53:39.879: cc_get_feature_vsa count is 1
Apr 20 13:53:39.879: :FEATURE_VSA attributes are: feature_name:0,feature_time:975739920,feature_id:94
Apr 20 13:53:39.879: //94/00F967C00C00/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=1104(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Apr 20 13:53:39.879: //94/00F967C00C00/CCAPI/cc_process_call_setup_ind:
Event=0x229B29B8
Apr 20 13:53:39.879: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Apr 20 13:53:39.879: //94/00F967C00C00/CCAPI/ccCallSetContext:
Context=0x21072E30
>>>>CCAPI handed cid 94 with tag 1 to app "_ManagedAppProcess_Default"
Apr 20 13:53:39.879: //94/00F967C00C00/CCAPI/ccCallProceeding:
Apr 20 13:53:39.883: //94/00F967C00C00/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=2, Params=0x21074428, Progress Indication=NULL(0)
Apr 20 13:53:39.883: //94/00F967C00C00/CCAPI/ccCheckClipClir:
Destination Pattern=0T, Called Number=0648956135, Digit Strip=TRUE
Account Number=Salon Marocain, Final Destination Flag=TRUE,
Guid=00F967C0-63BD-818F-0C00-10010A020705, Outgoing Dial-peer=2
Apr 20 13:53:39.883: //94/00F967C00C00/CCAPI/cc_api_display_ie_subfields:
The TP Configuration on CUCM (1104 to 0537810001) :
Thank you for helping me.
Youssef
04-20-2017 09:04 AM
So... you want to dial 0537810001, and have that ring 1104???
Because that's what your translation pattern does.
If you wanted to call 1104 and ring 0537810001, you're doing the complete opposite.
04-20-2017 09:47 AM
No, I want to translate the number 1104 to 0537810001, for external calls, how I can do that, thanks
04-20-2017 09:49 AM
Translation pattern is what you want to dial to match the pattern.
Called party transform mask is what you want to transform it into.
04-18-2017 12:37 PM
Hi Youssef,
I understand your problem. But your extension are such that they are not utilizing any property of the DID block that you have. What you are doing here is unique mapping to a DID so you would have to create a separate rule for all the extensions.
Pulkit
04-20-2017 03:03 AM
Hi Pulkit, thank you for your answer
After understanding my problem, you offer me the right solution, so In your opinion, where I can create separate rules for incoming and outgoing calls, in CUCM or in Gateway Router?
Thank you again.
Youssef
04-20-2017 03:43 PM
Hi Youssef,
It totally depends on you, where you feel comfortable about the translation:
I see that you have uploaded you TP, so if you can just check the checkbox for the "Use calling party's External Phone Number Mask" it would send the Caller ID to the GW and since you have not configured any translation on the GW it would work.
Again re-iterating the point that these are unique number and only 1 to 1 mapping would work.
Now coming to the GW, if you want to configure translation there:
voice translation-rule 201
rule 1 /^1103/ /0537810000/
voice translation-profile ANI_Conversion
translate calling 201
- Apply it now to the incoming or outgoing dial-peer:
translation-profile incoming ANI_Conversion
What the aforesaid configuration will do is it will change the calling number to 1103 to a DID of 0537810000.
Note: Based on the IOS version there is a limit to the number of rules that you can add. Earlier it used to be 15 however with IOS 15.1(4)M and above you can add 100.
Let me know if that helped.
Pulkit
