Calling Search Space bulk
clark white
Level 2
Level 2
I want to change a Calling search space for 200 users how can i do that through BAT, Is it possible.
Ayodeji Okanlawon
IT all d epends on which CSS yiuw ant to update. If it is device CSS, then you can use BAT>update phones>Custom file
ALl you  need to do is create a cusctom csv file with the mac address of the phones you wan to update thier CSS...Once you run the wuery and find the phones, then you can updat their CSS..
If it is line CSS, then you cant use BAT. You will need to use either Import/Export or A custom AXL script..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi Clark.
If you have contiguous DN you can do through bulk-->phones-->add/update lines --> update lines.
Here you can search for DNs you need to change CSS
Or you can export phones specifying all details, import in excel, modify what you need and reimport thruogh BAT.
Carlo
Please rate all helpful posts "The more you help the more you learn"
iptuser55
Level 6
Level 6
if you can not do the above, how phones do not require a css change? You could change the contents, name of the existing CSS so now it is now the new one and then manually redo the other phones, users to old CSS ?
