Calling Searchspaces and Partitions
jimihendrix1
The H.323 gateway incomming CSS only calls the first partion in the CSS list.Any partions after that it gives a busy.
Scenario I have phones in different partitions and I have applied the gateway with a CSS that contains all these partitions however that gateway can only contact the first partition.
At the moment I have to keep all phones in the same partition. I dont want this I want other phones to be in different partitions to take advantage of DID.
Thanks Guys
Dennis Mink
have you tried deleting the CSS and then re-add?
Please remember to rate useful posts, by clicking on the stars below.
Dennis Mink
I created a brand new CSS and added the appropiate partitions it did not work as I did not want to use dependancy records if I deleted original CSS.
Then finally I deleted the original CSS added partitions and works perfectly now.
Cheers minkdennis
