07-07-2016 09:56 AM - edited 03-17-2019 07:27 AM
We are running CallManager Administration 7.1.5 on IE 11. All of a sudden, it stopped working. We can get to the "splash" screen (http://10.223.6.3) but when we select Cisco CallManager Administraiton, we get a page cannot be displayed screen (https://10.223.6.3:8443/ccmadmin/showHome.do). Any ideas here?
07-07-2016 09:59 AM
Check the tomcat service status on CLI, you can try restart the tomcat services from the CLI mode.
utils service restart Cisco Tomcat
07-07-2016 10:19 AM
It seems like the issue is with IE. The version on my computer is:
ie 11.0.10240.16942
Update Versions 11.0.32
However, this is the version on another computer that works:
ie 11.0.9600.18230
Update Versions 11.0.29
Any thoughts?
07-07-2016 10:26 AM
Yes , i believe you have found this urself, i was assuming no user is able to access the webpage.
You can change the IE mode/engine when you press F12 and use computer icon with emulate mode to emulate previous versions.You can try other browsers as well to see if it works .
