I'm considering the passcode to control the IDD calls.
Which one is better on CM CMC passcode / ISDN passcode?
Can I control which one bind on the indicated IP-Phone? That mean I cannot use A user passcode on B user's phone.
On the other hand, I'm looking for some accounting bill on IDDs report .... That just is using the TFTP to collect the CDR records and run a program to generate the report monthly? Any free software can work on my small size company as starting?
