12-21-2009 05:35 AM - edited 03-15-2019 08:51 PM
I have a problem with qsig trunk between Cisco Callmanager express 7.1 and Siemens Hipath 3000.
If the cisco user is calling to siemens, the siemens phone does not display the name, only the number.
From Siemens to Cisco, everything is working fine.
So my question is:
1)what is the default qsig type for CME 7.1 is it ISO or ECMA?
2)how can I change the type from ISO to ECMA and ECMA to ISO
There are several discussions regarding CUCM, but not the Callmanager express.
David
12-21-2009 05:59 AM
Please take "debug isdn q931" with "term mon".
12-21-2009 07:41 AM
here is the output of the debug, btw I'm using Callmanager Express, so it's not H.323 GW or MGCP.
Dec 21 15:40:12.424: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 173
Dec 21 15:40:12.424: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x0195 callID = 0x8116 switch = primary-qsig interface = Network
Dec 21 15:40:12.424: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0195
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9FAA068001018201018B0100A111020201A602010080083137332054657374
Facility i = 0x9FAA06800100820100A11002010502010080083137332054657374
Progress Ind i = 0x8183 - Origination address is non-ISDN
Display i = '173 Test'
Calling Party Number i = 0x0080, '173'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0725540600'
Dec 21 15:40:12.568: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8195
prov-prh1#
prov-prh1#
prov-prh1#
prov-prh1#
prov-prh1#
prov-prh1#
prov-prh1#
Dec 21 15:40:17.628: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8195
Dec 21 15:40:17.716: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8195
Progress Ind i = 0xA590 - Reserved value
Locking Shift to Codeset 5
Codeset 5 IE 0x32 i = 0x80
Dec 21 15:40:19.900: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8195
Dec 21 15:40:19.904: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 0725540600 N/A
Dec 21 15:40:19.904: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0195
prov-prh1#
prov-prh1#
prov-prh1#
Dec 21 15:40:23.768: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8195
Cause i = 0x8090 - Normal call clearing
Dec 21 15:40:23.768: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0 disconnected from 0725540600 , call lasted 3 seconds
Dec 21 15:40:23.768: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x0195
Dec 21 15:40:23.812: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8195
prov-prh1#
Thank you very much.
David
12-21-2009 07:46 AM
CME is sending calling number both in QSIG format and regular IE:
Consequently, the problem is on the PBX, you cannot do anything about, you have to ask the PBX technician.
12-21-2009 07:56 AM
siemens phone is displaying only the number not also the name "173 Test". The Siemens guy is able to configure his PBX Q.SIG ECMA or ISO, do you know which one is better or more usefull for cisco callmanager express? Or am I able somehow to finetune my config?
e.g.
prov-prh1(config)#interface serial 0/0/0:15
prov-prh1(config-if)#isdn supp-service name calling ie 40 profile ROSE operation-value-tag ?
ecma use ECMA OID global value 0x06 04 2B 0C 09 00
iso use ISO OID global value 0x06 05 28 EC 2C 00 00
local use local value 0x02 01 00
So I'm not sure about the following commands:
prov-prh1(config-if)#isdn supp-service name calling ?
ie name ie value
operation-value-tag Specify the operation value tag
profile Specify the protocol profile
prov-prh1(config-if)#isdn outgoing ie ?
called-number CALLED NUMBER IE in outgoing ISDN messages is allowed
called-subaddr CALLED SUBADDR IE in outgoing ISDN messages is allowed
caller-number CALLER NUMBER IE in outgoing ISDN messages is allowed
caller-subaddr CALLER SUBADDR IE in outgoing ISDN messages is allowed
connected-number CONNECTED NUMBER IE in outgoing ISDN messages is allowed
connected-subaddr CONNECTED SUBADDR IE in outgoing ISDN messages is allowed
display DISPLAY IE in outgoing ISDN messages is allowed
extended-facility EXTENDED FACILITY IE in outgoing ISDN messages is allowed
facility FACILITY ie in outgoing ISDN messages is allowed
high-layer-compat HIGH LAYER COMPAT IE in outgoing ISDN messages is allowed
low-layer-compat LOW LAYER COMPAT IE in outgoing ISDN messages is allowed
network-facility NETWORK FACILITY IE in outgoing ISDN messages is allowed
notify-indicator NOTIFY INDICATION IE in outgoing ISDN messages is allowed
progress-indicator PROGRESS IND IE in outgoing ISDN messages is allowed
redirecting-number REDIRECTING NUMBER IE in outgoing ISDN messages is allowed
user-user USER USER IE in outgoing ISDN messages is allowed
Thank you!
david
12-21-2009 08:26 AM
Sorry, I should have said that you are sending the calling name also, see the string in hex:
Regarding the settings you mentioned, these are quite obscure, I never had the need to change them. Hope you can find the right combination, good luck!
