03-02-2010 06:39 AM - edited 03-15-2019 09:35 PM
Dears,
I just used DMA to migrate from CallManager 4.3 to CUCM 7.
When i restored the config on the CUCM7, the phones were not registered. I noticed that the callmanager service is down. If i start it, it starts for 30 seconds then go back to its down status.
Can anyone help please and guide me how to find the problem?
Moustafa
03-02-2010 06:52 AM
You have to upload your licenses.
This will help you:
1. Perform a Backup and Recovery System (BARS) backup.
2. Run Data Migration Assistant (DMA) export on the existing system.
3. Obtain the new license file using the upgrade process in the Cisco Unified CallManager documentation.
4. After receiving the new license file, send an e-mail to licensing@cisco.com requesting rehost of this license on the new cluster (publisher).
5. Obtain an Extended Markup Language (XML) license file from export and send it to licensing@cisco.com to do a rehost of this license. Also provide the MAC address of the new publisher. The same quantity of device license units and nodes will be returned with the new MAC address.
6. Perform a fresh install of Cisco Unified CallManager 5.1, DMA import, and upload license files received in step 3.
7. If the installation fails, reinstall the basic input/output system (BIOS), reinstall Cisco Unified CallManager, and reinstall BARS restore.
Hope to help.
Best regards,
- Adrián.
03-02-2010 06:57 AM
Hi Adrian,
thank you for your reply...
Is it mandatory to upload the licenses in order to make it work.
I need to test the whole functionality on CUCM 7 before getting the license. What do you advise?
Your help is really appreciated...
Moustafa
03-02-2010 07:01 AM
The SW license is MANDATORY if you want to turn on CCM service and register phones.
If you don't have it, you get the behavior you described.
Even if you just want to test, you need ALL the necessary licensing.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
03-02-2010 07:04 AM
Moustafa,
You can't test your system if your CM Service is always down (as you see, the phones will never become registered ). The only way I found to keep CM Service up and working as expected is to upload the license files.
Hope to help, if it does please rate.
Best regards,
-- Adrián.
03-05-2010 02:49 AM
I got a license for only one phone for testing (not for all phones), i also deleted all other phones except the licensed phone and
it is still not working...
Can anyone help please?
thanks
03-05-2010 03:12 AM
Hi There,
If you only want to test the CUCM 7 functionality, without obtaining the licenses, you will have to install CUCM as a clean(new) installation.Do not choose the upgrade from windows option. Then all your services (including Callmanager) will run. Your phones will also register. The drawback is that you will have to reinstall CUCM 7, with an ugrade version when you want to use your DMA export file. That's how I did it.
03-05-2010 03:18 AM
Thank you chabasimon for your fast reply...
Do i have to configure all phones manually? or What?
How can i test the phones feature without getting the config via DMA ?
Can you explain the following in details "The drawback is that you will have to reinstall CUCM 7, with an ugrade version when you want to use your DMA export file".
Thanks again
Moustafa
03-05-2010 03:39 AM
1. Do i have to configure all phones manually? or What?
Yes, It is a clean installation. You have to configure CUCM Server with the basics of what you need to test, i.e Device pool, Partitions,CSS,Route patterns/list/group etc.
2. How can i test the phones feature without getting the config via DMA ?
You don't need DMA to test the phone features. Just configure your server with Auto-registration information and your phones will register.
3. Can you explain the following in details "The drawback is that you will have to reinstall CUCM 7, with an ugrade version when you want to use your DMA export file".
I was trying to say that once you are done testing, you will have to do a new installation but this time you will have to choose the upgrade from windows option which will need your DMA export file. You will have to follow the normal upgrade procedure which requires the licenses, including the "Feature license" which is the one needed to sort out your callmanager service issue.
Hope this helps.
03-05-2010 03:53 AM
Well... I thought you have restored the config in another way than using DMA.
My goal is to test the same callManager 4.3 configs on cucm 7 config on a testing CUCM server before buying a new MCS server and getting the licenses. And as i know you cannot upgrade two times from callmanager on two different mcs servers, cisco licensing won't send the licenses the second time. That is why i want to test it and make a presentation before taking the purchasing desicion.
Thanks you...
