Calls are getting dropped by CUBE
Madhura Joshi
Setup has CUCM 8.6.2 on which all the phones are registered. And those phones are using CUBE as a gateway for PSTN calls (CME, as SIP trunk is provided by STC)
60% of the PSTN calls are getting dropped and gets message from the CUCM: “your call cannot be completed as dialed..”
The call flow is as follows:
IP phone --> CUCM --> SIP trunk --> CUBE --> SIP trunk --> service provider
Any help regarding this, would be highly appreciated.
Madhura
Hi Madhura.
Can you please activate a debug ccsip messages on CUBE and capture the output when a call fails?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Anas and Carlo, thanks a lot guys for the reply.
Will capture the debugs. But it would be difficult to capture the output for the call failure. Because, 40% of calls are not being failed. So, I cant anticipate the output for failure/success call.
In fact, I have already captured the debugs from CUBE as well as CUCM. Will capture the fresh debugs and will ping here.
Madhura
Anas Abueideh
Level 9
Level 9
also please share the SDL traces from the call manger, with exact calling and called number
enable the traces in the call manager to the detailed level
Anas
