07-15-2011 10:19 AM - edited 03-16-2019 05:58 AM
If I'm logged out of a Cisco IP Phone that has the Cisco CallManager Extension Mobility feature configured for it, would I be able to make a 911 call?
07-15-2011 11:17 AM
That will depend on how your logged out device profile is configured (CSS and Partitions). If the logout device profile (usually the configured phone in Device > phone) does not have access to the 911 route pattern via CSS it will not be able to dial 911
HTH,
Chris
07-18-2011 10:03 AM
Thanks Chris.
Is there any documentation I can use in order to configure this scenario properly?
07-18-2011 10:15 AM
Hi Avi,
Yes, you can check out the CUCM Features and Services guide and the extension mobility section outlines the steps pretty well, you can view it here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmfeat/fsem.html
Also, for the specific logout profile to answer your question, it can be found by going to Device > Phone, scroll down to Extension Information and click the Enable Extension Mobility checkbox and select the logout profile. By default it is set to Use Current Device Settings.
HTH,
Chris
Please rate helpful posts
