Calls not completing - (102) Call terminated when timer expired
jrusselliv
Have FXS ports on a CUBE that are controlled via MGCP.
Calling - ITSP - SIP - CUBE - SIP - CM - SIP - CUBE /w FXS - Called
The calls are not completing and we are seeing (102) Call terminated when timer expired in the traces. This was working but not sure when it stopped since end users do not use the FXS ports often.
Aeby Vinod
Level 3
Level 3
Can you try resetting the MGCP gateway with a no mgcp, mgcp, if thats not helping please provide the following debugs and show commands along with CCM traces from CMO2 and CM01for a failed call.
show voice port summary
show voice call summary
debug vpm signal
debug voip ccapi inout
debug mgcp packet
Please rate if you find this helpful.
Aeby
Aeby
