Calls to one extension are ringing on two seperate extensions
Alketron
This issue just started happening last week. In our office when one of our employees receives on a call on their extension, say extension A, a separate user, on extension B is also receiving the same call.
I have checked in CUCM and each users IP phone only has their primary extension linked to it. I am fairly new to using CUCM but could someone recommend where to look inside CUCM or Unity to solve this issue.
Thank you,
Alketron
Thank you for the responses. The solution was a simple one.
The user has accidentally hit the "Forward All" button on their phone and then typed extension B. After disabling Forwarding on the IP phone the problem was fixed.
5 Replies 5
Andrew Skelly
Level 7
Level 7
Have you looked at the configuration for Extension A to confirm there is no single number reach (mobility) configured on it to ring to extension B or that there is no Call Forwarding to Extension B?
Please rate helpful posts by clicking the thumbs up!
SNR cannot be configured with internal extensions
java
if this helps, please rate
Actually it can be if you send the call back out the network (PSTN).  I just tested and verified this on 11.5 SU6.  I placed SNR on my primary extension (line 1) to go to my secondary extension (line 2).  I configured the destination number as the DID of the extension.  So while yes it is not going directly to the internal extension the call is still triggering SNR to flow to the Destination Number configured.
Jaime Valencia
See if there are pickup groups configured for that DN, and confirm the call flow to discard a line group with broadcast
java
Alketron
