Calltracer 7.2.0: help!
raziel78kain
Level 2
Level 2
I'm trying to use Calltracer 7.2.0 (http://www.myvoipsource.org/open-source-tools/calltracer/) with a CUCM 7.1.
I have followed the "readme" file to configure it, but it seems it doesn't work...
Has anyone used this software successfully and can help me?
Thanks in advance for your help!
Best regards.
6 Replies 6
raziel78kain
Level 2
Level 2
anyone is using this software?
Regards.
I have tried the software with the latest CUCM version (8.6(x)), but it still doestn't work.
Unfortunately, I can't find other documentation than the "readme" in the .zip file, so I can't troubleshoot it.
Anyone can help me, please?
Regards.
finally, I was able to start the service of the software (INS-Calltracer).
Unfortunately, the software still does'n work.
In "calltracer.log", I can see this error:
org.myvoipsource.framework.axl.exception.AxlException: Error executing the http post request: AxlError: Authentication failture for axlUser  -> check config!
The weird thing is that the AXL user and the CTI user in "config.yml" are the same, and that the same log file states:
[DEBUG] CtiConnectionProvider: Connected to provider with user
What's wrong?
TIA and regards.
did you ever get this application to work?
unfortunately, no.
Regards.
Thats a shame,
I like the idea it is phone service based and can look in the personal directory not just a global directory.
