Can Anyone help to explain why character \ is used in Route pattern. also if you could explain *11\+1.289201XXXX
Can Anyone help to explain why character \ is used in Route pattern. also if you could explain *11\+1.289201XXXX ?
Ayodeji Okanlawon
This is taken from a recent post by William Bell.. I quote it here for you..
You use the backslash ("\") character in a route pattern when you  want CUCM to treat a wildcard pattern as a literal character. The "+" is  a wildcard pattern that matches one or more occurrences of the preceding digit or wildcard value.
So,
9+11 would match 911, 9911, 999911, etc.
If you want to treat the "+" as a literal character then you need to use \+.
* is a valid digit..as anyother digit you dial
X-is any number range from 0-9
Hence in your example..*11\+1.289201XXXX, you can dial the following numbers
*11+12892010000 - *11+12892019999
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Execellent explanation summerizing everything!
Best Regards
