Can I change the password "ccmadmin" ?
Fabio Alvarenga
     Hi Guys,
    I could  have some problem with change password "ccmadmin."?
    I need to change the password from time to time.
Aaron Harrison
Hi Fabio
You can log in and change this from the 'User Management/Application Users' menu.
Alternatively, you can do it from the CLI if you are locked out.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Aron
I know the way. What I want to know if there is any problem in changing password from time to time.
Best regards,
Fabio
There shouldn't be any problem with that. It's generally best to set that account to an unknown password and have other administrators use their own accounts with appropriate group membership to perform admim tasks.
In some cases an engineer might have used the ccmadmin account for services - e.g. such as UCCX AXL access, or some other similar case. What they should have done is used specific service accounts with appropriate rights.
Aaron
