Can I integrate SPA8800 with CUCM?
webstd.design
Can I use SPA8800 in VoIP network? I mean will it be clear configuration and vision when there aren't needs and possilibities to install ISDN PRI line on the remote branch office but presents analogue FXO line.
Thank you
paolo bevilacqua
I recommend you only use Cisco IOS GW for FXO. You can also use ISDN BRI that is very feature-rich.
Linksys products are really only consumer grade and can give you a lot of problems.
