07-08-2009 02:53 PM - edited 03-15-2019 06:52 PM
I found an Asterisk doc that said I should be able to find SIP firmware at the site below. But when I go there I see only a PDF. Is Cisco still supporting SIP firmware for the 796X series of phones? Where would I find the firmware? Is there an SKU that would allow one to purchase a Cisco phone with the SIP firmware already loaded on it??
http://www.cisco.com/pcgi-bin/tablebuild.pl/sip-ip-phone7960
http://download-sj.cisco.com/pub/voice/ip-phone/sip-7960/phnrn82s.pdf
http://www.asteriskguru.com/tutorials/cisco_7960_ip_phone_configuration.html
Solved! Go to Solution.
07-08-2009 03:38 PM
FW is in download center, you just need to look for it.
Go to download center and follow this path:
Voice and Unified Communications > Cisco Unified IP Phone 7965G > Session Initiation Protocol (SIP) Software > 8.5(2)
java
if this helps, please rate
07-08-2009 03:38 PM
java
