08-29-2024 02:23 PM
Sorry if this has been asked and answered many times, but: I have not accessed the web interface on my CP-7861-3PCC in quite a while. When I tried recently, I could not get through.
08-29-2024 11:42 PM - edited 08-29-2024 11:43 PM
Hello @jim20
Do you start to troubleshoot ?
Ensurebyou ping the phone first. Do you enable Web access from CUCM? Restart the phone ?
08-30-2024 05:59 AM
OP said 3PCC, so it’s not CUCM. Assuming the OP isn’t being disrespectful and has actually tried searching for an answer already, it’s off by default and can be enabled in the phone settings menus. It’s also controllable remotely by the config files it downloads if registered to a call control platform that understands how to manage it (e.g. Webex Calling, Ring Central, etc.) It’s possible that those platforms have forced it off if not visible in the phone config menu.
08-30-2024 07:22 AM
I have Ring Central. On the phone, on Admin Settings, "Enable Web Server" is set to "On". Any idea where to go in Ring Central to switch it on there, as well. Thanks!
08-30-2024 08:24 AM
Also, I wonder if it could be the firmware on the phone. Where can I find out what the current firmware version is? Thanks!
