05-12-2014 07:32 AM - edited 03-16-2019 10:45 PM
I'm having trouble blocking an incoming number on a Cisco 2811 configured as an h.323 gateway. I followed this guide here - http://blog.ipexpert.com/2009/03/21/blocking-calls-based-on-ani/. Everything seems to work okay. I can even successfully test the translation rule (test voice translation-rule 1 123), but when I call the main number with the phone that's supposed to be block, it still goes through. What am I doing wrong?
Solved! Go to Solution.
05-14-2014 01:25 PM
Hello Justin,
I don't see the translation-rule in the attached configuration.
if you would like to block the specific calling number, please configure the translation rule and apply it to the inbound dial-peer as instructed in this URL.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/64020-number-voice-translation-profiles.html#con13
you may also refer this post for further information
https://supportforums.cisco.com/discussion/12116111/blocking-calls-incoming-calls-gateway-router?tstart=0
if the call is still not rejected, please collect the "debug voice ccapi inout" for a test call and include the specific calling number & called number to verify which translation rule and dial-peer they macth.
//Suresh
Please rate all the helpful posts.
05-12-2014 08:44 AM
05-12-2014 09:21 AM
05-12-2014 10:35 AM
05-12-2014 10:37 AM
I did, but how do I retrieve the log?
05-12-2014 10:52 AM
05-14-2014 12:20 PM
05-14-2014 12:31 PM
05-14-2014 01:01 PM
05-14-2014 01:25 PM
Hello Justin,
//Suresh
