08-15-2011 11:15 PM - edited 03-16-2019 06:29 AM
Hi.
I want to create a Hunt Pilot Number as a Helpdesk No, where i want to distribute the call on the basis of Calling Party No (STD Codes).
Ex. My Pilot No. is 1800000001. When a person calls from UK, according to his STD Code, the call should be directed to UK Helpdesk Department.
Same if a person from US Calls the Same Pilot No, this time the call should be directed to US Helpdesk Department.
Is it possible to configure in CUCM 8.5 and how?
Thanks in advance.
Solved! Go to Solution.
08-16-2011 02:49 AM
Hi.
The frist thing I can suggest you is to work ar voice gateway level (if H323 or SIP) using answer-address and translation profiles to redirect calls to different hunt pilot nation related.
Of course you have to configure one hunt pilot and one line group fir each "source nation".
Hope this helps.
Bye
Carlo
08-16-2011 03:56 AM
as Calro mentioned
this is possible by using H323 Voice gateway using the command answer address and translation rules
for example
you need to have two additional dial-peers with answer-address command ( answer-address = the calling number )
once you have a match tne tranlslate the called number to the hunt groups number
example
voice translation-rule 1 --- translate to huntgorup1
rule 1 /.*/ /12345/
voice translation-profile hunt1
translate called 1
voice translation-rule 2 --- tranlsate to huntgorup2
rule 1 /.*/ /6789/
translate called 1
voice translation-profile hunt2
translate called 2
dial-peer voice 1 pots
answer-address xxxxx
translation-profile incoming hunt1
direct-inward-dial
dial-peer voice 2 pots
answer-address yyyyy
translation-profile incoming hunt2
direct-inward-dial
please note that the numbers in the above example xxx or yyyy they need to be the calling numbers exactly as they how the telco send it to your voice gateway
also make sure these new dial-peers dose not over lap with any existing dial-peer and other dial-peer dose not take over this one
if you have another incoming dial-peer pots with the command incoming-called-number .
please replace this command with answer-address . ( the dot mean any number )
if helpful Rate
08-16-2011 02:49 AM
Hi.
Hope this helps.
Bye
Carlo
08-17-2011 12:34 AM
Hiii
Thanks Carlo and Marwanshawi.
Your reply are really helpful.
Cureently i am studying "Voice Gateway Translation Profiles" and "Answer-address" as suggested by both of you.
Then i will try to tune them accrding to my scenario.
Thanks once again.
Cheers
Pankaj
08-17-2011 05:25 AM
good luck and pls rate the helpful posts
08-16-2011 03:56 AM
as Calro mentioned
for example
example
rule 1 /.*/ /12345/
translate called 1
rule 1 /.*/ /6789/
translate called 1
translate called 2
direct-inward-dial
direct-inward-dial
if helpful Rate
09-07-2011 02:00 AM
Hii
Thank you once again Carlo and Marwanshawi.
Your suggestions helped me a lot to achieve the requirement. I have tested it. The calls are being matched using translation rules and transfered to the intended extensions in Hunt group by matching 'answer-address'.
Cheers
Pankaj
09-07-2011 02:20 AM
thanks for the update and rating
glad to help
09-07-2011 02:32 AM
Many thanks to you for rating.
Glad to help me too.
Carlo
