Activate NIC teaming on Unity Connection v8.x , what with license?
david.vanherck
We have a Cisco Unity Connection v8.0.3a running without NIC teaming. What will happen if we activate the NIC teaming? A License MAC will be generated, so the old licenses won't work anymore? Will Unity Connection continue to work for 30 days after as in VM's? Granting us some time to have a new license for our Unity Connection...
Greets,
David
David,
You should be ok to activate network failover on your UCXN server.   I don't believe UCXN uses License MACs like UCCX does.  As far as having 30 days after a license expires, I'm not sure.   I thought you'll have to restart the Connection services but I might be thinking of Unity.
Glenn
James Hawkins
Level 8
Level 8
The virtual MAC address used for licensing should not change if you enable NIC teaming.
I have done this a few times without problems.
You should not need to rehost the license or even restart any services.
Thanks for the feedback! :-)
I've read some info in the "System Administration Guide for Cisco Unity Connection Release 8.x", chapter "Managing Licenses in Cisco Unity Connection 8.x" where they talk about licenses on Physical Servers: http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsag310.html#wp1074732 Here they state that the MAC address of NIC1 is duplicated to NIC2.
I checked our CUCM, where we activated failover during installation and this is what we have:
admin:show status
Host Name    : BE-VOIP001-MSL
Date         : Wed Sep 7, 2011 12:35:15
Time Zone    : Central European Summer Time (Europe/Brussels)
Locale       : en_US.UTF-8
Product Ver  : 8.0.3.20000-2
OS Ver       : 4.0.0.0-43
License MAC  : E41F136A22AC
Uptime:
12:35:17 up 174 days, 17:44,  1 user,  load average: 0.40, 0.22, 0.18
CPU Idle:   94.25%  System:   01.00%    User:   04.75%
  IOWAIT:   00.00%     IRQ:   00.00%    Soft:   00.00%   Intr/sec: 1134.34
Memory Total:        4127944K
        Free:          26848K
        Used:        4101096K
      Cached:        1355112K
      Shared:              0K
     Buffers:          27804K
                        Total            Free            Used
Disk/active         25197220K       12650488K       12290740K (50%)
Disk/inactive       25197252K       23839388K          77888K (1%)
Disk/logging        87665856K       67215668K       15996972K (20%)
admin:show network failover detail
Bond 0
DHCP         : disabled           Status     : up
IP Address   : 10.192.127.38      IP Mask    : 255.255.255.224
Link Detected: no                 Mode       : Auto disabled, N/A, N/A
Queue Length : 0                  MTU        : 1500
MAC Address  : e4:1f:13:6a:22:ac
RX stats:
bytes   :   2946974348   packets :   1654166567   errors :            0
dropped :            0   overrun :            0   mcast  :    327913883
TX stats:
bytes   :   2294166784   packets :   1233723360   errors :            0
dropped :            0   carrier :            0   colsns :            0
Ethernet 0
IP Address   :                    IP Mask    :
Link Detected: yes                Mode       : Auto disabled, Full, 100MB/s
Queue Length : 1000               MTU        : 1500
RX stats:
bytes   :   1700754458   packets :   1351741192   errors :            0
TX stats:
Ethernet 1
RX stats:
bytes   :   1246219890   packets :    302425375   errors :            0
dropped :            0   overrun :            0   mcast  :            0
TX stats:
bytes   :            0   packets :            0   errors :            0
DNS
Primary      :                    Secondary  :
Options      : timeout:5 attempts:2
Domain       :
Gateway      : 10.192.127.33 on Ethernet bond0
So the NIC1 is similar to NIC2 and also the Bond0 is the same MAC address. The License MAC is identical to Bond0, so all MAC addresses are the same if you activate failover.
We hope that this is also the case for Unity Connection, but this we'll now this weekend ;-)
Thanks for helping me! :-)
Greets,
David
