07-09-2012 03:34 PM - edited 03-16-2019 12:06 PM
My carrier claims that the Cisco 3845 voice gateway by sending a default prescendce level on the PRI trunks for MLPP is the reason I cannot place outbound calls on my new trunks. Can you even disable this setting? I don't have this problem on other identicle PRI's for the same carrier and they claim the gateway is not sending the prescedence. Any help is much appreciated.
07-09-2012 05:55 PM
Have you confirmed via some debugs that you're indeed sending some extra data on that PRI vs the ones that are working?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
07-09-2012 07:26 PM
Could you get the running configuration of a working and non-working gateway. And also, the new trunk is added to existing Route Groups and Route Lists in the CUCM ?
Thnx
